Being a DSP based radio, the BF888 is a cheap low power analog only RF package. Given the lack of discriminator and modulator access it is limited.
For a receiver the Maxtrac / Radius / GM300 work well. For a transmitter not so much. Heat output and with the Maxtrac, problems with power and deviation control out of band can cause problems without custom firmware or hardware hacks.
My absolute favorite RF gear for Analog / Digital repeaters is Tait. The T800 series is a purpose built programmable Exciter / Receiver package. With access to all the signals anyone would want. I started using them for 927 MHz repeaters and have had great performance on UHF and VHF. Mix and match at will. Pair a VHF receiver with a UHF or 900 MHz transmitter for a nice RF linked receiver site. For link radios simplex nodes and "Hot Spots" I've come to favor the Tait T2000 mobiles. They are easy to program, well documented, lots of IO and run cool in transmit.
The above is not to say there are not a LOT of great repeater / node packages out there. The GE MASTR II comes to mind. I have to mention the Micor to keep the flack down. I've built repeaters using everything from a Motorola 30D to current equipment.
Your mileage may vary.
73, Steve N4IRS
(o o)
-----ooO-(_)-Ooo------
— N4IRS was Here —
Well my personal experience with a baofeng node is really good audio reports, and sometimes better than my motorola SM-50 discriminator audio. I just use the internal tone decoder in those baofeng radios for COR.
Can I have an explanation of why discriminator is needed for anything but actual digital modulation like 9600 baud?
To prevent PL tones?
Nope, when plugging in good headsets I can hear the CTCSS tone from the repeater and even on the baofeng.
Lack of high frequency noise?
Put a high pass filter
Someone please explain why discrim is needed. Good audio is good audio and can’t it be manipulated to fit the needs of the application?
On 9/24/2015 9:30 AM, Skyler Fennell wrote:
Maybe I don’t want other filters inline, I want total control of the receive audio. de-emphases CTCSS filtering etc.
If worried about audio levels, put an AlC which automatically feeds the system (weather Allstar or free star) with the perfect level independent of the level of the user.
My absolute favorite RF gear for Analog / Digital repeaters is Tait. The T800 series is a purpose built programmable Exciter / Receiver package. With access to all the signals anyone would want. I started using them for 927 MHz repeaters and have had great performance on UHF and VHF. Mix and match at will. Pair a VHF receiver with a UHF or 900 MHz transmitter for a nice RF linked receiver site. For link radios simplex nodes and “Hot Spots” I’ve come to favor the Tait T2000 mobiles. They are easy to program, well documented, lots of IO and run cool in transmit.
The above is not to say there are not a LOT of great repeater / node packages out there. The GE MASTR II comes to mind. I have to mention the Micor to keep the flack down. I’ve built repeaters using everything from a Motorola 30D to current equipment.
Is it possible to use a URIx for freestar yet or do you still need a hardware board for the digital stuff? I know they were working on something for software.
Digital needs unfiltered receiver and transmitter audio. I've done
it with D-STAR and DMR. I have only setup a SM-50 as a user radio.
Steve
transmit.
73, Steve N4IRS
(o o)
--- N4IRS was Here ---
To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter
your email address and press the “Unsubscribe or
edit options button”
You do not need a password to unsubscribe, you can
do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
detailing the problem.
This should be on the freestar reflector I think (re: “dstarrepeaterd” program – the “sound card” DSTAR modem)
I found that the low-pass filtering in the URI limits the frequency response so that it does not reproduce the baseband signal with enough fidelity to work on DSTAR GMSK. The result is a lot of errors on the DSTAR side. As posted many times on the other reflector, the absolute cheapest sound fob with no filtering seems to work best (but make sure your transmitter has at least some filtering).
Having said that, as an experiment, I changed the relevant surface-mount capacitors in one channel, of one of my URIs, and it worked fine on DSTAR.
Digital needs unfiltered receiver and transmitter audio. I’ve done it with D-STAR and DMR. I have only setup a SM-50 as a user radio.
Steve
73, Steve N4IRS
(o o)
— N4IRS was Here —
Do you do your own repairs to the Tait radios? I have a Tait repeater. Their USA headquarters is about a mile from my home. I took the repeater to them for repair, and they flat out do not work on anything of theirs that is not now narrow band. No exceptions period, not even for amateurs. That sucks, no compassion for us hams.
N5ZUA
Yes, I agree with you that the 888 has amazing audio for being a $12
radio!
While I haven't personally tested the 888 for the various parameters
needed to make a high-speed MODEM work (such as needed for D-STAR or
9600baud packet radio), I don't expect the 888 would ever be suitable.
High speed MODEMs require a very clean and consistent audio pass band,
hence why discriminator audio and direct modulation are used. Without
getting deeply into the details, what I mean by this is that audio
processing and various filtering (e.g.: high-pass to eliminate PL tones
and low-pass for de-emphasis, etc.) causes frequency-specific audio phase
shifts and changes in group delay. None of this particularly matters to
the human ear. But, to a high speed MODEM, these minute changes are deal
breakers--the MODEM won't be able to decode. Years ago (in the packet
radio era) there were some good articles with photos describing all this
in detail. I'll try to find more info if you're interested?
73, David KB4FXC
Would they not be suitable for DSTAR though?
> On Thu, Sep 24, 2015 at 7:41 AM, Steve Zingman <szingman@msgstor.com> > > wrote:
>>> and can't it be manipulated to fit the needs of the application?
>>> Maybe I don't want other filters inline, I want total control of the
>>> Please note I'm only talking analog.
>>> 73
>>> Skyler KD0WHB
>>>> 73, Steve N4IRS
>>>> (o o)
>>>> _______________________________________________
>>>> App_rpt-users mailing list
>>>> "Unsubscribe or edit options button"
>>>> You do not need a password to unsubscribe, you can do it via email
>>>> confirmation. If you have trouble unsubscribing, please send a message to
>>>> the list detailing the problem.
> Skyler Fennell
> amsatnet.info
> KDØWHB
So what you are saying is that freestar only allows the DSTAR network if you are coming in from a digital modulation, if the switch is flipped to analog, it disables the network?
On Thu, Sep 24, 2015 at 12:26 PM, Ken ke2n@cs.com wrote:
You can transmit GMSK containing the DSTAR encoding with a cheap sound card. The hard part is finding a radio that passes 1 Hz to about 6 kHz with a fairly flat passband.
The freestar folks have a way to toggle operation between analog and digital, if you want (see VA3UV web pages).
The “Network” activity is managed by separate linking programs that talk to the repeater software module. If you were in analog mode, the linking programs would not get any data and they would not do anything on the network that linked the DSTAR machine to a reflector or other repeater.
I should probably move this to a DSTAR/free star group but here is my last question:
If I want a radio to transmit digital, I can use software with a cheap sound card. Correct?
Is there any way to use a sound card to transmit analog audio while still connected to the DSTAR network?
Steve
73, Steve N4IRS
(o o)
— N4IRS was Here —
PM, Ken <>
wrote:
You
encoding with a cheap sound card.�� The
passband.
The
The
�Network� activity is managed by separate
software module.� If you were in analog
So:
yes.
Regards
Ken
Skyler Fennell [mailto:
Thursday, September 24,
2015 1:29 PM
Ken <>
**Subject:** Re: [App_rpt-users]
AllStar Node / repeater radios
I should probably
If I want a radio
Correct?
Is there any way to
DSTAR network?
On Sep 24, 2015, at 8:28 AM, Ken < >
wrote:
This
�dstarrepeaterd� program � the
�sound card� DSTAR modem)
I
GMSK.� The result is a lot of
errors on the DSTAR side.� As
filtering).
Having
DSTAR.
Regards
Ken
KE2N
Skyler F [
Thursday, September
24, 2015 10:17 AM
Re:
[App_rpt-users] AllStar Node /
repeater radios
Is it possible
software.
On Thu, Sep
24, 2015 at 8:15 AM, Steve
Zingman < >
wrote:
Digital
a user radio.
Steve
On
9/24/2015 10:05 AM,
Skyler F wrote:
Well
my personal
experience with a
baofeng node is
really good audio
reports, and
sometimes better
than my motorola
SM-50 discriminator
audio. I just use
the internal tone
decoder in those
baofeng radios for
COR.�
Would
they not be
suitable for DSTAR
though?
On
Thu, Sep 24, 2015
at 7:41 AM, Steve
Zingman < >
wrote:
On 9/24/2015
9:30 AM, Skyler
discriminator
is needed for
anything but
actual digital
modulation
like 9600
baud?
To prevent PL
tones?
Nope, when
plugging in
good headsets
I can hear the
CTCSS tone
from the
repeater and
even on the
baofeng.
Lack of high
frequency
noise?
Put a high
pass filter
Someone please
explain why
discrim is
needed. Good
audio is good
audio and
can’t it be
manipulated to
fit the needs
of the
application?
Maybe
I don’t want
other filters
inline, I want
total control of
the receive
audio.
de-emphases
CTCSS filtering
etc.
which
automatically
feeds the
system
(weather
Allstar or
free star)
with the
perfect level
independent of
the level of
the user.
Please note
I’m only
talking
analog.
Skyler KD0WHB
On
Sep 24, 2015,
at 7:15 AM,
Steve Zingman
wrote:
Being a DSP
based radio,
the BF888 is a
cheap low
power analog
only RF
package. Given
the lack of
discriminator
and modulator
access it is
limited.
For a receiver
the Maxtrac� /
Radius / GM300
work well. For
a transmitter
not so much.
Heat output
and with the
Maxtrac,
problems with
power and
deviation
control out of
band can cause
problems
without custom
firmware or
hardware
hacks.
My absolute
favorite RF
gear for
Analog /
Digital
repeaters is
Tait. The T800
series is a
purpose built
programmable
Exciter /
Receiver
package. With
access to all
the signals
anyone would
want. I
started using
them for 927
MHz repeaters
and have had
great
performance on
UHF and VHF.
Mix and match
at will. Pair
a VHF receiver
with a UHF or
900 MHz
transmitter
for a nice RF
linked
receiver site.
For link
radios simplex
nodes and “Hot
Spots” I’ve
come to favor
the Tait T2000
mobiles. They
are easy to
program, well
documented,
lots of IO and
run cool in
transmit.
The above is
not to say
there are not
a LOT of great
repeater /
node packages
out there. The
GE MASTR II
comes to mind.
I have to
mention the
Micor to keep
the flack
down. I’ve
built
repeaters
using
everything
from a
Motorola 30D
to current
equipment.
Your mileage
may vary.
73, Steve
N4IRS
� � � � (o o)
— N4IRS was
Here —
App_rpt-users
mailing list
To unsubscribe
from this list
please visit and scroll
down to the
bottom of the
page. Enter
your email
address and
press the
“Unsubscribe
or edit
options
button”
You do not
need a
password to
unsubscribe,
you can do it
via email
confirmation.
If you have
trouble
unsubscribing,
please send a
message to the
list detailing
the problem.
12:26 PM, Ken <>
wrote:
You
passband.
The
The
So:
yes.
Regards
Ken
Skyler Fennell [mailto:]
2015 1:29 PM
Ken <>
I should probably
If I want a radio
Correct?
Is there any way
wrote:
This
I
Having
Regards
Ken
KE2N
Skyler F
Thursday, September
24, 2015 10:17 AM
Re:
repeater radios
Is it
software.
On Thu, Sep
Zingman <> wrote:
Digital
Steve
On
9/24/2015 10:05 AM,
Skyler F wrote:
Well
my personal
experience with a
baofeng node is
really good audio
reports, and
sometimes better
than my motorola
SM-50
discriminator
audio. I just use
the internal tone
decoder in those
baofeng radios for
COR.
Would
they not be
suitable for
DSTAR though?
On
Thu, Sep 24,
2015 at 7:41 AM,
Steve Zingman
wrote:
On 9/24/2015
9:30 AM,
Skyler Fennell
discriminator
is needed for
anything but
actual digital
modulation
like 9600
baud?
To prevent PL
tones?
Nope, when
plugging in
good headsets
I can hear the
CTCSS tone
from the
repeater and
even on the
baofeng.
Lack of high
frequency
noise?
Put a high
pass filter
Someone please
explain why
discrim is
needed. Good
audio is good
audio and
can’t it be
manipulated to
fit the needs
of the
application?
Maybe
I don’t want
other filters
inline, I want
total control
of the receive
audio.
de-emphases
CTCSS
filtering etc.
which
automatically
feeds the
system
(weather
Allstar or
free star)
with the
perfect level
independent of
the level of
the user.
Please note
I’m only
talking
analog.
Skyler KD0WHB
On
Sep 24, 2015,
at 7:15 AM,
Steve Zingman
wrote:
Being a DSP
based radio,
the BF888 is a
cheap low
power analog
only RF
package. Given
the lack of
discriminator
and modulator
access it is
limited.
For a receiver
the Maxtrac /
Radius / GM300
work well. For
a transmitter
not so much.
Heat output
and with the
Maxtrac,
problems with
power and
deviation
control out of
band can cause
problems
without custom
firmware or
hardware
hacks.
My absolute
favorite RF
gear for
Analog /
Digital
repeaters is
Tait. The T800
series is a
purpose built
programmable
Exciter /
Receiver
package. With
access to all
the signals
anyone would
want. I
started using
them for 927
MHz repeaters
and have had
great
performance on
UHF and VHF.
Mix and match
at will. Pair
a VHF receiver
with a UHF or
900 MHz
transmitter
for a nice RF
linked
receiver site.
For link
radios simplex
nodes and “Hot
Spots” I’ve
come to favor
the Tait T2000
mobiles. They
are easy to
program, well
documented,
lots of IO and
run cool in
transmit.
The above is
not to say
there are not
a LOT of great
repeater /
node packages
out there. The
GE MASTR II
comes to mind.
I have to
mention the
Micor to keep
the flack
down. I’ve
built
repeaters
using
everything
from a
Motorola 30D
to current
equipment.
Your mileage
may vary.
73, Steve
N4IRS
(o o)
— N4IRS was
Here —
App_rpt-users
mailing list
To unsubscribe
from this list
down to the
bottom of the
page. Enter
your email
address and
press the
“Unsubscribe
or edit
options
button”
You do not
need a
password to
unsubscribe,
you can do it
via email
confirmation.
If you have
trouble
unsubscribing,
please send a
message to the
list detailing
the problem.
