Mark,
This may be a dumb question, but are you using the VPN feature of the router. This may be your issue.
How are you getting your internet connectivity?
Cable, u-verse, wireless ISP? If you are using a cell phone based hot spot for internet connection, some carriers block IAX ports.
I have checked and you are correct your two nodes are not hitting the registration server.
Have you changed or edited anything in you rpt.conf lately?
Here are some other things to check.
Lets double check the basics first.
Log into the computer running your ASL node.
From the linux CLI: ( Pi@rptr:~ $ )
sudo ping -c2 8.8.8.8
sudo ping -c2 google.com
making sure it has internet connectivity and can resolve domain names.
type: sudo asterisk -rvvv
you should then be in the asterisk command line interface ( CLI ) for short.
Connected to Asterisk 1535 currently running on rptr (pid = 29510)
Verbosity is at least 3
rptr*CLI>
type: iax2 show registry
rptr*CLI> iax2 show registry
44.98.254.145:4569 Y 49203 YOU.R.IP.HERE:4569 60 Registered
this will show what your node is trying to do for registration.
make sure the node number and password are correct
https://wiki.allstarlink.org/wiki/Beginners_Guide#Edit_Node_settings for example.
and the line is not commented out with a semi-colon ( ; ) at the beginning of the line
https://wiki.allstarlink.org/wiki/Iax.conf example.
Marshall - ke6pcv
From: Mca555 via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Friday, October 25, 2019 5:20 AM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] Allstar Link registration fails when behind a NAT router
Mca555
October 25
I’ve installed a new router and I now can no longer get nodes to register. How can I tell if a TP-Link TL-R600VPN V4 changes the source port? Can the port be forced to 4569? Am I missing something obvious? [ likely! ]
The nodes are 46987, 45534.
Thanks!
Mark
