Hi All, after so many years (installed 2011) of using the AllStar system flawlessly, now the EchoLink side of it has stopped.
I see this error when someone tries to connect...
"Connected to Asterisk currently running on hub (pid = 2110)
Verbosity is at least 3
[Oct 27 17:54:41] ERROR[2221]: chan_echolink.c:2578 do_new_call: Cannot find DB entry for IP addr 107.23.146.139
[Oct 27 17:54:42] ERROR[2221]: chan_echolink.c:2578 do_new_call: Cannot find DB entry for IP addr 107.23.146.139
[Oct 27 17:54:44] ERROR[2221]: chan_echolink.c:2578 do_new_call: Cannot find DB entry for IP addr 107.23.146.139
[Oct 27 17:54:46] ERROR[2221]: chan_echolink.c:2578 do_new_call: Cannot find DB entry for IP addr 107.23.146.139"
I can't think of anything that has changed on my network, or router.
AS node 28052
EL node 244279
ZS5PMB-R
Is anyone able to assist please? We can even pay for your time if necessary. Teamviewer session?
Yup, unable to connect via EL, but could through AS. Both AS and EL sites show you as registered. I’m wondering if something happened to your software load to get corrupted. I used to have that issue until I went with the RPi a couple of years ago. A reboot would often correct the issue. I later discovered a USB issue that caused asterisk to not be happy, and seemed to be corrupting my load. This is a mystery to me.
The IP address below is reported as computer.amazonws.com. Does this make sense to you? Not seeing any connection with your issue, but curious.
Thanks for your help, Bob. After a couple of reboots (about 6) it
just started working again.
Shaun
ZR5S
The IP address below is reported as computer.amazonws.com .
issue, but curious.
Bob
k6ecm
Sent from my iPhone
On Oct 27, 2017, at 9:52 AM, Shaun Rudling <shaun@pmbnet.co.za >
wrote:
[http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter your email
address and press the “Unsubscribe or edit options button”
You do not need a password to unsubscribe, you can do it
via email confirmation. If you have trouble unsubscribing,
