This may sound like a dumb question but in all the research on Allstar I have not found a clear answer. Do I first need to install a physical VOIP line or does port 4569 take care of this through emulation.
You don’t need a VoIP line added to your location. Yes, 4569 UDP is the “VoIP line”.
It would be a good idea to have this documented somewhere. Thank you.
I just marked my answer as the solution. Google will find it. Consider it documented.
