Allstar connecting to Echolink?
Does anyone know if this should work still? I can’t seem to be able
to get my allstar node to register on the echolink system as active. Everything works when i use the echlink app and the firewall settings are in place. Callsign is N9JPG-L.
thanks
[Mar 1 19:20:00] WARNING[539]: chan_iax2.c:10127 iax2_do_register: REGISTER-LOG: Sending registration request for ‘28970’
[Mar 1 19:20:00] WARNING[541]: chan_iax2.c:7690 registry_rerequest: REGISTER-LOG: registry rereqquest
-- Received OK from Echolink server [nawest.echolink.org](http://nawest.echolink.org)
-- Directory pgm done downloading(partial,
compressed), 647 records
Thanks to those that responded… i had waited several hours/days without the node appearing active and do not have a second client running simultaneously within my network. The later responses indicated the search for my node failed to find a match, but that was because the wrong callsign was used. See below.
cruiser*CLI> echolink dbget c N9JPG-L
960818|N9JPG-L|71.194.253.53
Below that is my echolink.conf file for reference. Note the servers listed - 1,5,3.
I used these in my conf file as it noticed that was what my echolink client was using.
server1=nawest.echolink.org
server2=nasouth.echolink.org
server3=servers.echolink.org
Make sure you point the echolink ports in your router to your allstar server and as was mentioned you can only run one echolink node per public IP address.
As noted earlier, that is all set as suggested on the howto page for allstar to do echolink.
Any other ideas?
thanks
