Ive run the sstart up script on to get to teh part where I key up on DMR via my hotspot to never see any traffic which then never starts the bridge
so Im wondering now if anything in the software has changed that I need to update?
Im able to use my dmr radio to connect anywhere so its making connection
seems the issue is in the bridge…
Mike
July 2, 2023, 12:31pm
2
Mike, what exactly are you calling a ‘bridge’ ?
From the sounds of it, you are more likely to be having a port number issue on the input of dmr from source.
But I will await a better detail before commenting more.
k6jwn
July 3, 2023, 3:56pm
3
Are you bridging using DVSwitch? If so, try their groups.io support site: main@DVSwitch.groups.io | Home
Otherwise, if that’s not the case, like Mike mentioned, we will await further details before being able to assist.
