AllScan issue on ASL3
I installed AllScan v.0.88 on my ASL3 node. I can log in but cannot connect to a node. ASL3 and Allmon 3 work fine. The detail window keeps repeating the error below:
Connecting to Asterisk Manager 611662 127.0.0.1:5038…Login OK
ASL Ver: 2.0/unknown, AllScan Ver: 0.88
“Thou Shalt Not Clip The ADC” - The 1st Law of AllStar
ASL version does not support RxAudioStats
ERROR: XStat failed!
ERROR: sawStat failed!
Event Source error: Check internet/LAN connections and power to node
Any ideas what is wrong and how to correct this?
You probably do not have the Asterisk Manager Interface (AMI) credentials set or you may have changed them. The other messages in the info window will show what file the AMI info is being read from. If you can post that here or email david at allscan.info I can let you know what you need to do.
