Allowing Incoming Connections
I tried searching but not able to find anything on this topic. How do I enable incoming connections to my node? I have a "hotspot" connection in my home as my node.
Thank you
Michael
Michael, when you say "hotspot", I'm assuming you are using a connection which is tied to a mobile carrier which does not allow port forwarding. If this is the case, your option here is to install openvpn or wireguard vpn, you'll rent a server from a provider, i recommend racknerd for the cheapest servers that are reliable. GitHub - angristan/wireguard-install: WireGuard VPN installer for Linux servers GitHub - angristan/openvpn-install: Set up your own OpenVPN server on Debian, Ubuntu, Fedora, CentOS, Arch Linux and more
No, I am referring to the device that is connected to my home wireless network that gives me access to Allstarlink. In this case a device connected to a RPi 4b.
NAT incoming UDP/4569 to your Node's IP address. You'll need to give it a fixed IP address.
