I had a problem getting two LAN nodes to display on allmon3. 'Put them on different ports. The solution was to change monport= to port= in /etc/allmon3/allmon3.ini. Is that documented somewhere?
OS Kernel : 6.12.96+deb13-amd64
Asterisk : 22.9.0+asl3-3.9.3-1.deb13
ASL [app_rpt] : 3.9.3
Installed ASL packages :
Package Version
allmon3 1.9.1-1.deb13
asl3 3.18-2.deb13
asl3-asterisk 2:22.9.0+asl3-3.9.3-1.deb13
asl3-asterisk-config 2:22.9.0+asl3-3.9.3-1.deb13
asl3-asterisk-modules 2:22.9.0+asl3-3.9.3-1.deb13
asl3-menu 1.18-1.deb13
asl-apt-repos 2.0-1.deb13
cockpit 337-1+deb13u1
cockpit-bridge 337-1+deb13u1
cockpit-networkmanager 337-1+deb13u1
cockpit-packagekit 337-1+deb13u1
cockpit-storaged 337-1+deb13u1
cockpit-system 337-1+deb13u1
cockpit-ws 337-1+deb13u1
dahdi 1:3.1.0-2.1
dahdi-linux 1:3.4.0-11.asl.deb13
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: Skipping evaluation of private node 1970
Info: rpt.conf has configuration for: 29520, 29521, 29522, 43456, 48398, 409871, 41170, 42610, 42947, 27714, 27654, 29454, 43455, 413731, 451461, 542220, 29826, 40562
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 18 registration line(s)
Info: Registrations present for configured node(s): 29520, 29521, 29522, 43456, 48398, 409871, 41170, 42610, 42947, 27714, 27654, 29454, 43455, 413731, 451461, 542220, 29826, 40562
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 136.49.235.253
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 136.49.235.253
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 136.49.235.253
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 136.49.235.253
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 136.49.235.253
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 136.49.235.253
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
