Allmon3 v1.2.0 has been released to GitHub . Allmon is the standard web-based monitoring and management for the AllStarLink application. Allmon3 is the next generation of the venerable Allmon2 that is rewritten for performance, scalability, and responsiveness
Installation and configuration may be found in the README.md . Version 1.2.0 maintains 100% configuration compatibility with the 1.1.x and 1.0.x release series.
During installation, if changes to custom.css have not been merged in during the dpkg installation process, please consult /usr/share/doc/allmon3/custom.css for the greatly-increasing number of UI customizations available.
Changes and Fixes for v1.2.0
- Fix missing await in ws_voter keepalive which leads to crash of Voter display (fix #191)
- Fix reloading user database when called in USR1 handler (fix #192)
- Only enable Apache2 modules in postinst when apache2 is installed (fix #195)
- Re-add missing python3-websockets dependency in debian/control (fix #196)
- Fix default CSS custom variables to match core code (fix #197)
- Fix and enforce correct mode and owner on password-containing files (fix #201)
- Fix
allmon3-passwdfrom overwriting elements out of order inusers(fix #204) - Clear"Login Failure" message on next success (fix #205)
custom.csssupports customizing the Node Transmit Line (fix #208)
