Allmon3 v1.0.2 has been released to GitHub . Allmon is the standard web-based monitoring and management for the AllStarLink application. Allmon3 is the next generation of the venerable Allmon2 that is rewritten for performance, scalability, and responsiveness
Installation and configuration may be found in the README.md . Version 1.0.2 maintains 100% configuration compatibility with the 1.0.x release series.
Command failures should be logged. Do you see anything in /var/log/syslog or if you don’t have syslog installed, journalctl -b -u allmon3.service? Should be tagged with ERROR.
