Allmon3 v0.10.2 Beta Released
The latest beta for Allmon3 is now available. The code is becoming quite stable and suitable for a wider audience. I expect v1.0 to be released sometime after ARRL Field Day.
Allmon3 v0.10.2 is a minor update to address bugs and other issues found in the 0.10.0 and 0.10.1 releases. The updates are:
  • Support per-node command templates (see web.ini)
  • Retain order of menu.ini submenus in the HTML dropdown
  • Add the command modals to the voter display page
  • Implement binding IP configuration directive (see web.ini)
  • allmon3_server objects now listen on all IPs by default
  • Fix apache.conf RewriteRule for v0.10
  • Expose in-browser websocket errors to the UI
  • Fix string formatting error for remote transmission status
  • Fix dependency issues in allmon3.service systemd service
Thanks to WD6AWP, KF0FCY, and DS5QDR for bug reports from the beta test
Yuk Spelt my Call Wrong !!
Lol…
Sorry! Doesn’t look like I can fix it here either.
