Help I have set up my node works with cli .When I log in to allmon3 I can key radio with time command OK, but when I try to access a node it says connected but doesn't key radio.
Are you saying that the Allmon3 "Say Time of Day (local only)" works?
Are you saying that the Allmon3 UI says that your node is connected?
What node doesn't key?
What behavior are you expecting from your node? from the node you are connecting to?
Yes time works and it says connected I forgot to say if I disconnect node it keys my radio
Thanks for your help i fixed it by reregeristing .
