Allmon3 page - NO node?
im new to Allstar, this is my 1st install. when i load the allmon3 page there is no node, what do i need to check ot what am i doing wrong, in the ASL menu / Diagnostics / show allstar registrations i can see “1 HTTP registration”
Thank you
Hi!
It could be that you have not set your node details in /etc/allmon3/allmon3.ini
Could you confirm you have done that? Configuration - AllStarLink Manual has some examples that you could use at the end of the file. Host would be 127.0.0.1 if allmon3 is installed on the same system as asl3 and user pass would be the ones from your /etc/asterisk/manager.conf file, usually default is under [admin] part so user will be admin.
Let us know if it works.
that got it, took a minute to get the password setup
thaNK YOU
