"Allmon3 is not responding to requests for this node. Check server logs."
I'm getting this error today out of nowhere. Everything has been working normally and today it just randomly started doing this. Passwords are correct in Allmon.ini and manager.conf. I can't find any logs as it says, so I'm not sure where to look. Everything else works so if there's no solution it will just stay broken. This is a raspberry pi 3 with the latest version of ASL3.
Did you check the server logs as prompted? journalctl -u allmon3.service.
