Allmon3 - iaxrpt and favorites?
I have noticed that when I use iaxrpt to connect to my node, nothing shows up on my Allmon3 page, but on the other hand, when I connect using RepeaterPhone, it shows me connected.
Would there be a reason that it would not show up in the Allmon3 page?
What is also interesting, i thought I would try it with the iax-client instead of iax stanza and noticed if I was connected that everything for the node goes away instead of when it is connected. Very strange for sure.
Last question, is it possible to add favorites to Allmon3, a new button that maybe accesses a favorites.ini file? Just a thought
You’re hitting a known bug in Allmon3 v1.3.x that will be fixed in the forthcoming v1.4.
There is no such functionality currently, no.
I understand there isn’t one currently, just making a suggestion for the future.
It would be really handy
Could you file an enhancement issue @ GitHub Allmon3 :slight_smile:
where on that page do I find it? Thank you
Following the above link should take you to the GitHub page for Allmon3. You should see a row of links with “Code”, “Issues”, “Pull Requests”, etc. You will want to click on “Issues” where you will find a “New Issue” button. That’s where you can file bug reports and enhancement requests.
thank you so much
Rob
For those watching this thread : Allmon3 Issue #259
Your user name in IAXRPT mades a difference.if I put my call in as my user name.
it shows up
If I use iaxrpt… Then I connect in “Stealth” mode
At least on my local repeater that’s how it works.
On my personal node… If I used my call as my user name it refused to connect.
use your call as a CALLERID name instead
