I have ASL3 installed on a Pi4 with 2gb as a radioless node. i use an S23 running DVSM to connect to the node… On the node i also have a Dvswitch server… i have allscan installed , works fine. My main problem is that when i run allmon dashboard i can connect/disconnect nodes ok, but if i’m connceted to my node from the fone the dashboard wont report connections even though i can use it to connect /disconnect? i have port 5038 port forwarded.
That is correct. It will not report a phone, for it is not a public or private node.
You could get visibility using iaxrpt as a iax-client without being a node.
Thanks Mike,
Its not a deal buster not to be able to see the connection, but was thinking i’d got something wrong in the set up?
I will continue to use Allscan for the connect/disconnect.
de Daryl G0ANV
