Found the answer to my own question so disregard... controlpanel.ini.txt has it all
Larry - N7FM
On 02/23/2016 09:49 AM, larry wrote:
This is more of a question for Tim Sawyer but Doug or others may have some input as well so decided to post it here.
First let me say...I run a mixture of Acid, BBB & RPi2 nodes and I am new user of Allmon.
Just recently I set up Allmon2 so I could group all my nodes on a single server for easy monitoring and control.
What I discovered was when using the Allmon2 Control Panel there is a selection option that says "Say Time of Day (local only) the TT way"
Not fully comprehending what the outcome would be .. the curiosity factor kicked in... Tried it!!Just happened to be controlling an ACID node at the time. It issued a *74 command defined on ACID servers as ilink,16 which is a "Reconnect links disconnected with "disconnect all links" command. On the BBB and RPi2 installs *74 is not defined by default. The equivalent Reconnect function calling ilink,16 is *77 on the BBB and RPi2 which is not available in Allmon2. Unless you defined a function *74 on the BBB or RPi2 there is no action by Allmon2 in its present configuration.
I do realize that ilink functions can be redefined numerically on a per node basis. I would assume it is also possible to customize option commands in Allmon along with caption of the function it will perform? Can you point me to the file to make or add command changes? Or is the solution to reprogram all nodes to match Allmon and whatever *74 is customized to perform on each node? if so the Control Panel option message ought to be changed as it is misleading.
Any Pointers?
Larry - N7FM
ohnosec.orgTo unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
