allmon2 setup Login issues
Hi everyone its Loren here again… I am trying to setup Allmon2 well actually i think for the most part i have it setup other than i can not login into the thing I have done just about everything i could think of anyone have any suggestions and what is the proper way to setup the password side of things i have the .htpasswd file located in a different folder than allmon does that make a difference i did change the function line under login.php maybei have missed some thing but just need some random thoughts on what i could have done wrong any and all thoughts are appreciated
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
http://www.lorentedford.com
http://www.Ltcraft.net
http://www.richlandcountycomputers.com
http://kc9zhv.lorentedford.com
http://newwavesucks.com
Oh forgot to mention every thing seems to be functioning http://hub.kc9zhv.com/
Re: [App_rpt-users] allmon2 setup Login issues
Do you have a user called admin defined in the .htpasswd file?
If not you will need that. Also do not forget the other definable file which permits you to define the functions you want to make available. You should not need to change the login.php file.
Keith
http://www.lorentedford.com <http://www.lorentedford.com/>
http://www.Ltcraft.net <http://www.ltcraft.net/>
http://www.richlandcountycomputers.com <http://www.richlandcountycomputers.com/>
http://kc9zhv.lorentedford.com <http://kc9zhv.lorentedford.com/>
keith@goobie.org
Keith Goobie
Richmond Hill, ON, CANADA
Ok i have switched the username to admin and reset the login.php still having issues what is the other file your talking about. define the functions you want to make available
Keith
keith@goobie.org
Keith Goobie
Email: lorentedford@live.com
Email: lorentedford@aol.com
Email: LorenCS@Ltcraft.net
Email: lorentedford@yahoo.com
Email: loren@lorentedford.com
Email: loren@richlandcountycomputers.com
Email: loren@newwavesucks.com
Phone: 618-553-0806
This one:
Edit controlpanel.ini.php for your desired commands. Be sure to keep the
labels and the cmds tags in assoicated pairs.
These become available when you login successfully.
Keith
Email: loren@lorentedford.com mailto:loren@lorentedford.com
Phone: 618-553-0806
Keith
On 3/21/15 5:31 PM, “Loren Tedford” <lorentedford@gmail.com <http://lorentedford@gmail.com> > wrote:
Email: lorentedford@gmail.com <http://lorentedford@gmail.com>
App_rpt-users@ohnosec.org <http://App_rpt-users@ohnosec.org>
keith@goobie.org
Keith Goobie
The .htpasswd file must remain in the same directory where you put allmon. The file is created with the Apache utility called htpasswd. The syntax is shown below.
for example: htpasswd -c .htpasswd admin
then pick a password.
[root@wd6awp allmon]# htpasswd ?
Usage:
htpasswd [-cmdpsD] passwordfile username
htpasswd -b[cmdpsD] passwordfile username password
htpasswd -n[mdps] username
htpasswd -nb[mdps] username password
-c Create a new file.
-n Don’t update file; display results on stdout.
-m Force MD5 encryption of the password.
-d Force CRYPT encryption of the password (default).
-p Do not encrypt the password (plaintext).
-s Force SHA encryption of the password.
-b Use the password from the command line rather than prompting for it.
-D Delete the specified user.
On Windows, NetWare and TPF systems the ‘-m’ flag is used by default.
On all other systems, the ‘-p’ flag will probably not work.
