New install of asl-beta from the download page of allstarlink.org.
Now that all is installed, and passwords set in allmon2 along with htpasswd I still
get “Login failed” when trying to access allmon2 (and supermon also) through
the web portal.
Placed passwords within the allmon.ini.php as required and did the “htpasswd -cB ./htpasswd admin”
at the command line, and verified that manager.conf password matches up… still a no go.
Suggestions/Hints on what I might have missed or where to start looking, please.
Thank you,
W R Howell
KI5PHN/WQYX489
If you want breakfast in bed, sleep in the kitchen…
I set those two from the final install, have changed them twice just to make sure they were entered correctly and still no go. I’ll just reinstall the whole works and go from there and see what happens.
No, I guess when I was typing it here I some how added a / without seeing it before I hit the submit button. The correct entry is "htpasswd -cB .htpasswd admin”, that which I actually used and still no go…
