M6GSN
February 22, 2023, 6:33pm
1
I have my ASL node in the cloud it’s all up and running but I can not get Allmon to connect to my node on the node page of allmon I get the message “Could not login to Asterisk Manager.”
my node all mon page can be viewed at http://58766.hopto.org/link.php?nodes=58766
any help will be welcomed
Glen
M6GSN
WD6AWP
February 22, 2023, 7:14pm
2
On your node edit /etc/asterisk/manager.conf
comment the bindaddr line, like so
;bindaddr = 127.0.0.1
Also add a permit line below the deny line, like so
permit=xx.xx.xx.xx/255.255.255.255`
where xx.xx.xx.xx is the IP of the server where Allmon is running. Then restart Asterisk
M6GSN
February 22, 2023, 7:31pm
3
thanks for your reply
Allmon in on the same server as my node.
made the edit and still the same
WD6AWP
February 22, 2023, 8:25pm
4
Sorry, thought your server and node were separate. In that case you should put the bindaddr back and you don’t need the allow.
Did you set the manager.conf and allmon.ini.php userid and passwords to match?
M6GSN
February 22, 2023, 9:29pm
5
once again thanks for getting back to me
here is a side-by-side screencap of manager.conf and allmon.ini.php
WD6AWP
February 22, 2023, 11:51pm
6
How about use 127.0.0.1 for the host. No port. Not needed when default 5038.
M6GSN
February 23, 2023, 7:57pm
7
WD6AWP:
allmon.ini.php
with local host I get "Feb 23 19:56:02] NOTICE[23910]: manager.c:1034 authenticate: 127.0.0.1 failed to authenticate as ‘admin’
== Connect attempt from ‘127.0.0.1’ unable to authenticate
Mike
February 23, 2023, 8:38pm
8
Perhaps you need to allow the port 5038 in the firewall.
WD6AWP
February 23, 2023, 8:43pm
9
Try a simple password, letters and numbers only. Some symbols cause a failure.
WD6AWP
February 23, 2023, 8:45pm
10
Allmon and AllStar are on the same server.
M6GSN
February 23, 2023, 9:52pm
11
the password makeup is purely alphanumeric could there be a character number length limit?
