I am very new to the allstar link. I have the ASL software loaded on a Pi3B+. Allstar shows that I key my node. I started the Allmon2 set up by typing the command … sudo apt install git
my response is:
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
git-man liberror-perl rsync
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitweb git-arch git-cvs
git-mediawiki git-svn
The following NEW packages will be installed:
git git-man liberror-perl rsync
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,168 kB/5,195 kB of archives.
After this operation, 27.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
When I answer yes, this is the response
Err:1 http://mirrordirector.raspbian.org/raspbian stretch/main armhf git-man all 1:2.11.0-3+deb9u2
404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
Where am I screwing this up?
thank you in advance
Dave
