Problem Node: 626790
allmon3 1.5.1-1.deb12
asl3 3.8-1.deb
Inquiry
Since the multiple updates this week:
I am unable to connect to Asterisk on the Problem Node. Using Allmon local to 626790, I couldn't log in (changed the username/password on Allmon), that issue resolved.. The Nodes do show, but each says: "Allmon3 is not responding to requests for this node. Check server logs."
From 626790 Message.log
025-07-02 07:02:37.847] NOTICE[58675] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-02 07:02:37.848] NOTICE[58675] manager.c: 127.0.0.1 failed to authenticate as 'admin'
I double-checked the secret, they are all the same, /etc/allmon/allmon.ini, /etc/asterisk/allmon3.ini.php, manager.conf
I assume, when I fix this issue, my issue of connecting from Supermon on 62649 will resolve itself.
That error is telling you that on the Asterisk side, there is no user named admin created - it's "nonexistent". That means that your manager.conf file is incorrect. It should look pretty much something like this:
[general]
enabled = yes
port = 5038
bindaddr = 127.0.0.1 ; Comment when not localhost access
[admin]
secret = >>SOMETHING SECRET<<
read = all,system,call,log,verbose,command,agent,user,config
write = all,system,call,log,verbose,command,agent,user,config
; By default asterisk will listen on localhost only.
[general]
enabled = yes
port = 5038
;bindaddr = 127.0.0.1 ; Comment when not localhost access
bindaddr = 0.0.0.0
[admin]
secret = my password
;deny = 0.0.0.0/0.0.0.0 ; Uncomment when not localhost
;permit=1.2.3.4/255.255.255.255 ; Uncomment when not localhost
permit=96.224.250.24, 100.77.7.64 ;SBANETWEB
[2025-07-04 06:17:57.476] NOTICE[65719] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:13.503] NOTICE[65723] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:13.503] NOTICE[65723] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:13.505] NOTICE[65724] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:13.505] NOTICE[65724] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:13.507] NOTICE[65725] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:13.507] NOTICE[65725] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:29.543] NOTICE[65726] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:29.543] NOTICE[65726] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:29.545] NOTICE[65727] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:29.545] NOTICE[65727] manager.c: 127.0.0.1 failed to authenticate as 'admin'
[2025-07-04 06:18:29.547] NOTICE[65728] manager.c: 127.0.0.1 tried to authenticate with nonexistent user 'admin'
[2025-07-04 06:18:29.547] NOTICE[65728] manager.c: 127.0.0.1 failed to authenticate as 'admin'
Was not intended to solve anything, just point out proper usage, and that it is was within asterisk educate to be clear, since that seem to be in question..
Well, no. And it has not been shown to be the result of an update, not saying it wasn't. Don't assume that. Causes you to limit your exploration for cause.
I have been waiting for information to surface that might lead the way since nobody likes to directly answer questions anymore.
But a slow response is likely when it is not getting info expected. It's likely 'retrying'.
Sorry, I don't use supermon to be any better guide here.
But you might tap the supermon user group at groips.io
You're still having the same issue: Asterisk does not believe that the user 'admin' you're trying auth with exists or is valid. This is almost assuredly some sort of configuration hiccup in /etc/asterisk/manager.conf. A software update would not cause this unless you were using some sort of syntax that is no longer valid with upstream Asterisk if your package upgrade just want from 20 to 22 but I don't recall any such deprecation being in Asterisk between those two versions.
