I’ve just configured an AllStar node on a Raspberry PI that uses a SHARI PiHat and HamVoip (see https://kits4hams.com/shari-pihat) . There is an allmon2 page at http://{ip address]/allmon2/ with a login link. What is the default username and password, and how do I configure Allmon2? I’m not even sure that Allmon2 has been installed as there is no /var/www/html/allmon2 directory
Not sure if shari is doing anything different then the beaten path.
So, if you were following their instruction, you should ask them.
But here is the standard install direction.
https://wiki.allstarlink.org/wiki/Allmon2_Install
Thanks Mike. I’ll ask Kit 4 Hams that supplied the SHARI kit. And thanks for the link
