I have just set-up a new Raspberry Pi Allstar node and for some reason i cant get the allmon to let me sign in, i have checked i have the right user name and password and the settings are the same as a friend but it still fails to let me in.
Does anybody have any suggestions please?
Hi
Its the login prompt on the IP Address of the Pi, but saying that i can RX & Tx using DVSM but my Portal Node settings are saying No in registered if that helps?
I do not know how DVSM is set up but the Allmon readme might help with the login issue.
As far as AllStar registration, what does your registration like look like? In /etc/asterisk/iax.conf you need a line like register=541190:your-passwd@register.allstarlink.org. However, as I said, I don’t know DVSM so ymmv. Check with the groups.io forum if you don’t get a better answer here.
Sorry for the delay i have had work taking over at the moment.
just to clarify do i need to open port 4569 on my router for my RP with Allstar node to work properly and my issue with Allmon is that when i use a browser to 172.16.1.47 which is my ip addrss of the RP and type in admin and the password set allmon tells me it isnt recoginsed for some reason!
Any ideas please?
