I am pulling the little hair I have left out of my head trying to figure this out. I have Allmon running with no issues on all my nodes except one.
I installed a second node along side a working node so I can use Zoiper when out on the road. Everything is working fine except it will not connect to Allmon. I copied the information from the already working node and just changed the node # as I have done in the past. The strange thing is that the first node is showing up fine!
Go in to one of your nodes copy the manager. Conf and the iaxrpt. Conf then past them in to a text file and save then go in to the node that failed do the same. Compare the files the one that works is your control files the other then should look like that one less the node info for the not working node. Ie pass word node number ect.
Here is what I did. I added a 2nd node onto a working RPI3, followed these directions “https://docs.allstarlink.org/node/139”. The first node on the pi shows up in allmon with no issues, the 2nd node shows cannot connect to asterisk manager. I have redone this 3 times now same results. The 2nd node is showing up on Allstar site as online and I can connect to other nodes.
Thanks. Sorry I just seen this reply. I’ll do better next time :).
Will this work with the latest ASL image? (someone told me it only worked with hamvoip)
And I assume as long as it is on node connect to a hub, all other nodes connected to the same hub will also be monitored?
Allmon will work on any node. Supermon (a derivative of Allmon) has been tailored for HamVoIP.
On hub nodes (keep in mind hub nodes are no different than any other node except they generally don’t have a radio wired to them) you will see all connected nodes. You can connect or disconnect any node to your node and you can control you’re node via the control panel.
