Hi need help with setting up the reflector
I install raspbian lite and also raspbian stretch
I can never get the menu to setup the the I’d
Name of the reflector and tg number
I try every thing I know and no luck
KB5HTB
Allstar is set up from our image which you download and copy to an SD card and then boot.
The image and instructions are on our WiKi. https://wiki.allstarlink.org/wiki/Main_Page. See the Downloads, Beginners Guide and FAQ.
Please let us know when you have any questions.
I had to google YSF, It looks like your’re trying to install Yaesu Fusion YSFReflector on your pi.
Allstarlink is a network for analog radios & repeaters. If you’re just doing digital you’ll probably need to start over with a distribution more suited for your use. Possibly just a straight Debian distro.
That being said, just from a general linux perspective, It appears you never downloaded install script you were trying to execute. The command wget will download a file off the web (web get).
You would have wanted to type the command
wget https://register.ysfreflector.de/install.sh
you would then probably have to change the permissions to make the downloaded script executable
chmod 705 install.sh
then execute it
./install.sh
Thank you Steve for you help the other scripts where installed ok but the scrip. bash install.sh
This the script or command where you fill the name of the reflector and location.
I just to have the asl program with the reflector
Working. Now won’t let me run it again.
So I did download the debian strech full
And have no issues loading the Ysf
I just tought the was something wrong with the asl program.
Again thanks for helping
KB5HTB
