All star account not right
Hi I have created an account on all star.org but when I go to portal then node settings I have no option to get a node number, only create a server which doesn’t appear to work. Am I doing something wrong or just being stupid??
Hello,
You must create a server, then you can request a node for the server.
I have tried that, when I fill out all the boxes & pick my location on the map, press submit, it doesn’t do anything but go back to create server.
What is your call sign? I’d be happy to take a look at your account. But I suspect you have a browser issue. What are you using? Is Javascript enabled?
Yes Java enabled. Tried multiple browsers. Call sign is M7NRT
Looks like you figured out what was wrong. I see your server and node. Good job!
Yes it was me being special :rofl: I had added the server but not set it up. Thanks for all your help
wh6wav I tried everything don’t know what I’m going wrong
Hello 97Waverider,
Please start a new topic (this one is closed) and describe the trouble you are having.
