** We have a node coming up in Lake Charles, La and we are having issues. So, I am asking for configurations suggestion. First off, the Allstar node is not going to be at the repeater site. It is at a remote site.**
It is running on GM300 with URI interface. The repeater has a long squelch tail of about 2 second. I have tried to run with USB radio in half duplex mode but the node ends up ping ponging with the repeater in half duplex mode .
Is it better to use simpleusb or USBradio for this type of setup?? Should the repeater squelch be reduced or turned off all together.
** Please offer a copy of either USBradio or simpleusb configuratio file pretty please.**
Re: [App_rpt-users] Advise for setup
If you are using PL on the repeater, they maybe some options for you. If you are not using PL, then you will have to look at options where a shorter squelch tail is used.
We run similar setups here at some of sites – taking advantage of PL to give the desired results.
Good All, We have a node coming up in Lake Charles, La and we are having issues. So, I am asking for configurations suggestion. First off, the Allstar node is not going to be at the repeater site. It is at a remote site. It is running on GM300 with URI interface. The repeater has a long squelch tail of about 2 second. I have tried to run with USB radio in half duplex mode but the node ends up ping ponging with the repeater in half duplex mode . Is it better to use simpleusb or USBradio for this type of setup?? Should the repeater squelch be reduced or turned off all together. Please offer a copy of either USBradio or simpleusb configuratio file pretty please.
** Yes the repeater is using PL but the PL does not drop with the COS/COR. It stays running the whole time including the squelch tail. This maybe on of the issues.**
73 de Angelo
PS: any configurations files you would like to share?
----- Original Message -----
Keith Goobie
To: Angelo Glorioso ; app_rpt mailing list
Sent: Wednesday, November 13, 2013 8:39 AM
Subject: Re: [App_rpt-users] Advise for setup
We run similar setups here at some of sites taking advantage of PL to give the desired results.
Good All,
** It is running on GM300 with URI interface. The repeater has a long squelch tail of about 2 second. I have tried to run with USB radio in half duplex mode but the node ends up ping ponging with the repeater in half duplex mode .**
** Is it better to use simpleusb or USBradio for this type of setup?? Should the repeater squelch be reduced or turned off all together.**
If you are using incoming PL for the users to key the repeater then it should follow their transmitted signal. If you are looking at the output of the repeater and the repeater is setup to transmit PL then PL will be present whenever the repeater is keyed. You can’t use the repeater output detected PL for Allstar. If you are at the repeater you can pickup the PL at the correct point. If you are using a remote link to the repeater then you will have to either modify the repeater so that its output PL follows the input or go to a two PL system where there is one output PL for the repeater and another follows the input. The second method allows repeater users to hear repeater ID’s and courtesy tones and both methods stop those from going out over Allstar. 73 Doug
WA3DSP WA3DSP Amateur Radio Resources
73 de Angelo
Keith Goobie
Good All,
*Good All,*
*It is running on GM300 with URI interface. The repeater has a long squelch tail of about 2 second. I have tried to run with USB radio in half duplex mode but the node ends up ping ponging with the repeater in half duplex mode . *
*Is it better to use simpleusb or USBradio for this type of setup?? Should the repeater squelch be reduced or turned off all together.*
*Any help would be appreciated.*
On 11/13/2013 08:01 AM, Angelo Glorioso wrote:
Angelo,
edit rpt.conf to change the hangtime of the repeater.
Also, find the [wait_times] stanza, also in rpt.conf and shorten them up, considerably.
Let me know if that doesn't get you pointed in the right direction and we'll go from there.
The best option would be to modify the repeaters PL to only be active during cos/cor, You may be able to add a second tone but that could cause other audio issues, but I have seen it done with success.
73 de Angelo
Keith Goobie
Good All,
Re: [App_rpt-users] Advise for setup I want to thank all who offered help. We have Lake Charles up and running now. It was a jumper setting
in the Motorola GM300.
** Thanks all, Geoff, Keith, and Doug**
Angelo Glorioso
To: Keith Goobie ; app_rpt mailing list
Sent: Wednesday, November 13, 2013 8:48 AM
Hi Keith,
73 de Angelo
** PS: any configurations files you would like to share?**
Keith Goobie
We are using USBradio.
Keith
On 11/13/13 9:01 AM, "Angelo Glorioso" <n5uxt@hotmail.com > wrote:
Good All,
