Utility to help test, adjust, and configure devices using the SimpleUSB Radio interface
Menu Use
asl3
this utility will best assist after programming the SA818 part of a USB dongle (see sa818-menu).
you will be able to adjust outgoing (TX) audio and check incoming (RX) audio levels, and view the COS, CTCSS, and PTT signaling in real-time. Echo mode and Flash can be used to verify correct dongle functioning.
Note: USB dongles (SA818 plus CM108 USB dongles) often do not supply a COS signal, and if you are unable to kerchunk your node, then change CTCSS From to 'no' instead of 'usbinvert'.
after a morning of writing some suggested content, i've cloned the repo and created SSH keys but have hit a roadblock:
$ git push origin fix-readme-add-script
ERROR: Permission to AllStarLink/ASL3-Manual.git denied to csylvain.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
adding simpleusb-tune-menu to the table of commands is easy enough, but i'm not sure where to put the longer description paragraph. any recommendation?
