ACID Error Lockup
I have an ACID distribution running. Last night I ran an "astres.sh" after minor change to the rpt.conf file, and everything went away. No radio, no internet, just dead. Details below. Has anyone dealt with this? {This is a Dell PC and an URI.}
I went to the repeater site and found the monitor filled with
"cannot submit datapipe for urb 0, error -22: internal error"
The last line was partially truncated. The keyboard was dead. Pressing the power button did not start a shutdown. Finally holding the power button down to dump the power and then restarting the machine brought things back to life. Any information appreciated.
...STeve - KF5VH
Hi Steve,
My #1 guess is PC hardware stability issues, roughly in this order:
Power Supply and/or fan(s), DRAM, MoBo, CPU.
Also, some MoBo's have poor cooling on various HOT components and start to
fail after several years.
One wonderful thing about Linux is that it's easy to swap boxes!
73, David KB4FXC
...STeve - KF5VH
Same experience with my last ACID build on a mini-ITX. Installed DIAL, which was a bit more forgiving. Troubleshooting revealed the USB hardware was degrading. Discovered stability returned after moving the nodes to two separate hubs on the motherboard. Having put the repeater back online with an interim RPi 2 using DIAL I decided not to use the Mini-ITX any more, after receiving complements on the audio quality with the RPi 2. Easy decision :slight_smile:
Bob
kk6ecm
Sent from iPad
...STeve - KF5VH
If you have updated system files, you might want to re-compile.
You might also want to turn off all built-in devices not in use in the bios set-up.
(parallel,serial, sound, some usb hubs etc)
IRQ / PNP issues. And force a update to the PNP data when done if not automatic.
Process of elimination in the end.
...mike/kb8jnm
...STeve - KF5VH
options button"
problem.
Mine would lockup as well had to power cycle it, I upgraded to DIAL I don't see that problem anymore. Been running DIAL for a while now I use to have this lockup couple times a week.
...mike/kb8jnm
...STeve - KF5VH
options button"
problem.
