How do I recover a node that I accidently erased?
Ron, Does your node still boot and what exactly got erased?
What happened was I was erasing another node number and when I hit erase I wasn’t payiing full attention and had moved to another node that should have been erased. It was attached to the controller on our club repeater.
Ron Anderson
Depending on exactly what was erased you may have to load a new image and start from scratch. If you got lucky and only deleted the /etc/asterisk directory, you could copy that from another server and make the node number changes.
Tim,
I think Ron means he deleted a node in the user portal
de k9wkj
Ah, that looks like the problem,. Thanks, @k9wkj
@Ron454 I’ve restored node 46397. Are you good now?
Thanks Tim
that keeps things running till we slide over to a NNX setup
