ACC RC-850 Audio ID
Our club is going to replace our ACC RC-850 with an ASL3 node. Is there any way to configure ASL3 to do ID with audio when the node has activity after being idle for some time.
The RC-850 if keyed after being idle for sometime after 10 minutes has passed with the last transmission it will play an specified audio file. I'm familiar with making it do something at a particular time/day etc., but not sure if ASL3 can act similar to the RC-850
The ACC RC-850 has the following IDs
Anxious ID
Periodic QST ID
3 Pending IDs
Special ID
3 Initial IDs
Dale, KC2CBD
I am very happy with the ASL3 Third-Party App “Herald”
Which does way more than just station ID-ing
Bill - W9LBR
Kinda like comparing a manual typewritter to a PC based word processor... de nu5d
It can do everything you ask and a whole lot more.
Check out
AI3I/app_rpt__ultra: app_rpt ultra :: the ultimate experience for your radio system
I have nothing to do with it, other than trying it briefly awhile back. It appears it may do what you wish with a little effort.
I wouldn't disagree, But the ACC RC-850 was a really advanced controller when it was on the market. Just think about it, the RC-850 was in the 80's and 90's.
If you search the forum, the entire extended vocabulary of ACC controllers was posted on here about a year or so ago.
EDIT: Looking at the Github account pic for that app ultra thing, it was the same guy.
Yes, I seen the audio vocabulary. Thanks though.
I do agree - I think I still have one ACC in the shed - and in the day paid $1000 for extra vocabulary. I remember the S9 Plus 60 Voice to this day...... I have been using Wyse Dell 3040's or even some older 5010 Dx0's with a $3 CM108 modified sound card (modified means remove the jacks and add a keying transistor and a couple of resistors to pad the audio levels) and let the software take care of CTCSS encode and decode and squelch. Very economical even if you never tie to the internet. Just as a stand alone controller.... de nu5d
✞ ΙΧΘΥΣ
Look for your id string setting for the node
idrecording = |kb8jnm ; id recording or morse string
idtalkover = |kb8jnm ; Talkover ID (optional) default is none
to something like this pointing to the audio file
idrecording =/etc/asterisk/msg/idmsg
idtalkover=|iKB8JNM/R
Formats must be compatible with your version of asterisk.
Should be precise info in the manual
I should add, this is not a 'waking id only'
Yes, app_rpt__ultra is still being actively maintained. The TI TMS5220 vocabulary used to hang out in a Dropbox repository, but I have since moved it into GitHub with the project. Yes, it will do initial, pending, anxious and special IDs. I don't believe I ever bothered with the periodic QST ID; it seems app_rpt will get an itch an ID at some point anyway, especially if your radio system sees any activity on a link, it's bound to ID anyway. Let me know if you have any questions...it's still going.
