Another note on the 16K audio track.
I’ve got 16K SLIN audio working well. As was noted in other places on this thread, the audio quality is noticeably better. It is useful in cases where network and audio bandwidth are less constrained. If you don’t care about higher audio sampling rates you should disregard the rest of this message.
I recognize that the G.722 CODEC supports 16K audio. At the moment I’m working with 16K SLIN because it’s easier to implement. However, I want to do this in a way that is completely compatible with the existing implementations (i.e. doesn’t create CODEC negotiation problems) and is also documented in the RFC. I’m trying to get RFC5456 clarified so I’m sharing some notes here in case anyone cares and/or has some expertise that is relevant.
Problem
I’m using higher-quality audio sampling rates in my IAX2 implementation, but I want to stay fully-compatible with existing Asterisk implementations.
RFC5456 defines a media format for 16-bit linear audio (0x00000040), but it isn’t completely clear what the sampling rate for this media format should be.
Most of the other IAX2 media formats have an implicit sampling rate.
I think (not 100% sure) that the Asterisk implementation of the 16-bit linear media format (0x00000040) assumes an 8K sampling rate. Anyone who knows better should correct me.
I can see that the Wireshark dissector for IAX2 is assuming that undocumented media format 0x00008000 is marked as “16K 16-bit linear audio,” so apparently someone has already gone down this path and claimed an unused media format codepoint for this purpose. (NOTE: I use this media format in my 16K audio implementation).
The RFC defines an information element called SAMLPINGRATE which is obviously relevant, but it is never explained how this element should be used.
The expert at IANA who is responsible for editing the RFCs and related numeric assignments is hesitant to allocate a new media format for 16K linear audio if the existing SAMPLINGRATE element could be clarified and used for its intended purpose.
It’s possible that I’d want linear audio at other higher sampling rates (for example 22.05, 44.1, 48k), so the point about leveraging SAMPLINGRATE is well taken. This is especially true given that the FORMAT element is limited to 32-bits.
Informative point: SIP addresses this problem by allowing sampling rates to be specified in the SIP INVITE message (example: a=rtpmap:96 G729/8000).
Proposal
The existing SAMPLINGRATE information element will be added as an optional element on the NEW and ACCEPT message (RFC5456 tables 6.2.2 and 6.2.3 respectively).
If specified, the SAMPLINGRATE element on the NEW message allows the caller to define the maximum sampling rate specified for any capable media formats for which the sampling rate isn’t implicit. (For example: the SAMPLINGRATE element isn’t relevant for G.711 uLaw because the 8K assumption is implicit in the ITU specification, but it might be relevant for G.729 where different sample rates are allowed).
If specified, the SAMPLINGRATE element in the ACCEPT messages allows the callee to define the sampling rate that will be used for the call, but only in cases where the media format has flexibility in this regard. The accepted SAMPLINGRATE must not exceed the maximum sampling rate provided by the caller.
The default sampling rate for any media format that has flexibility in this regard will be 8K. The most important example is 16K linear media format (0x00000040), which will default to 8K if no SAMPLINGRATE element is used.
