2175 Hz Tone Remote PTT
Greetings:
Is app_rpt capable of being configured for tone remote signalling? If so, how do I set that up?
I am going to interface to a MASTR III that is connected to other tone remotes also. I'm setting up to drive an external tone panel right now but it strikes me that this really shouldn't be necessary since the control tones could be generated and mixed within app_rpt.
73 DE Thor
Operator of N7JCT
http://ohnosec.org/drupal/node/94
This should get you started. Some scripting, either internally via the
Event Management Subsystem or externally in Linux, should be able to
get you what you want.
Brett KQ9N
On Tue, Oct 8, 2013 at 12:02 PM, Thor Wiegman <n7jct@aplaceonthe.net> wrote:
Greetings:
73 DE Thor
Operator of N7JCT
ohnosec.org
This is outstanding. That will certainly get me started and I have much to learn. How is the amplitude of the tones set?
On 10/08/2013 10:43 AM, Brett Friermood wrote:
ohnosec.org - ohnosec Resources and Information.
Brett KQ9N
Greetings:
73 DE Thor
Operator of N7JCT
ohnosec.org
I'm not sure if it can be adjusted independently. Since that function
is for sending paging tones instead of control tones it's logical that
the amplitude is fixed. Maybe Jim or one of the other developers will
chime in.
Another way I can think of would be to produce proper amplitude sound
files in Audacity and use the same scripting to playback those files
at the proper times.
Brett KQ9N
Brett KQ9N
On Tue, Oct 8, 2013 at 12:02 PM, Thor Wiegman <n7jct@aplaceonthe.net> >> wrote:
Greetings:
but
73 DE Thor
Operator of N7JCT
ohnosec.org
