2026.10.11 - Package Updates - Beta Channel
We continue to release updates to the ASL3 project. With all new packages, we start off sharing the updates with our developers. Then, the packages are moved to the “beta” package channel for those who want to test fixes to their problems or get the “latest and greatest” as quickly as possible. When we believe that the changes are OK for all we push them out to the production channel.
Before opting to install the "beta" (or "devel") packages we ask that you carefully read Beta Testing about the caveats and potential pitfalls of beta packages.
The following ASL3 packages are now available from the "beta" channel. The changes include:
asl3-asterisk 22.10.1+asl3-3.10.8-1
  • app_rpt
    • app_rpt.c: Add ct per remote node #1270
    • app_rpt.c: don't cycle channel ref while sending textq PR #1279
    • app_rpt.c: Hangup l->pchan as soon as it is no longer needed PR #1282
    • chan_echolink: Queue answer frames after releasing the node list PR #1310
    • app_rpt: Tell the peer to stay down when a dialplan timeout drops the link PR #1311
    • app_rpt: Run discpgm on a local EchoLink or TLB link-off PR #1312
    • chan_voter: refactor UDP reading and master client timestamp PR #1318
    • app_rpt.c: Don't mix telemetry audio that is already in an altlink audio path PR #1319
    • chan_echolink.c: Address deadlocks across multiple mutex PR #1320
    • rpt_cli: Keep channel variable listings off a missing rx channel PR #1322
    • app_rpt.c: Check rxchannel exists and get a reference in cli thread PR #1323
    • res_usbradio: Use a dynamcic sleep time in ast_radio_pa_read() PR #1329
    • add AGENTS.md CLAUDE.md PR #1330
These packages will be available for the next 1-2 weeks. If we do not hear of any issues or problems with the updates we will promote them to the production/main channel.
Sincerely,
AllStarLink
This update has an issue for me and one other user I know for voting systems. The master voter looses timing. See log below. The only noticeable pattern is the warning messages appear in pairs about 5 seconds apart.
[2026-10-13 11:35:59.846] WARNING[1628673] chan_voter.c: Lost master timing client, disconnecting remaining clients.
[2026-10-13 11:36:05.846] WARNING[1628673] chan_voter.c: Lost master timing client, disconnecting remaining clients.
