2026.03.17 - Package Updates - Beta Channel
We continue to release updates to the ASL3 project. We start off sharing these updates with our developers, then to the “beta” package channel for those who want to test fixes to their problems or get the “latest and greatest” as quickly as possible. When we believe that the changes are OK for all we push them out to the production channel.
Before opting to install the "beta" (or "devel") packages we ask that you carefully read Beta Testing about the caveats and potential pitfalls of beta packages.
The following ASL3 packages are now available from the "beta" channel. The following are highlights of the changes:
NOTE: The updated asl3-asterisk packages include a newer version of Asterisk (22.8.2) and many changes to app_rpt including one BIG change. We have removed our dependency on the DAHDI kernel module!!! The package post-installation scripts will make a few needed changes to the modules.conf, rpt.conf, and extensions.conf configuration files.
asl3 3.13.0
  • asl-telemetry: Deal with non-ASL IAX connections PR #170
  • asl-find-sound: show device serial number (if present) PR #172
  • Add a tool to exhaustively check node authentication PR #173
asl3-asterisk 22.8.2+asl3-3.8.2-1
  • asterisk
    • Update from Asterisk 22.7.0 to Asterisk 22.8.2
  • asl3-asterisk
    • Add support for asterisk 23.1 PR #70
    • asl-dahdi-repair‎: add logic to check for apt/dpkg PR #72
    • build-asl3: add support for asterisk 22.8+, 23.2+ PR #73
    • Add udev rule for hidraw CM1xx PR #75
    • Allow .conf files in "/etc/asterisk/custom" PR #76
    • Updates to support asterisk (non-DAHDI) bridging PR #77
    • dadhi minimization, improve asterisk clone PR #80
  • app_rpt
    • conf: Add templating to iax.conf to support multiple authenticated clients PR #591
    • app_rpt: Remove dependency on DAHDI PR #865
    • app_rpt: Change rpt_safe_sleep from calls originating in rpt() to 20ms PR #904
    • chan_voter: Update Keepalive Debug Messages PR #907
    • app_rpt: enumerate l->disced PR #908
    • app_rpt: Add {} to ilink cases where variables are defined PR #909
    • app_rpt: Add missing mutex around myrpt->links list traversals PR #910
    • app_rpt: Add comments around altlink() and audio frames PR #911
    • chan_voter: Add client connect message PR #912
    • chan_simpleusb/chan_usbradio: manage "devstr=", add "serial=" PR #916
    • app_rpt: Use passed variable chan in rpt_radio_set_recommend_data() and rpt_radio_set_param() PR #917
    • app_rpt: Remove requirement for ident to be defined/configured PR #918
    • app_rpt: Use ast_str for stats url PR #924
    • app_rpt: pthread_create_detached() -> pthread_create() as we join at shutdown PR #926
    • app_rpt: Address memory leak in http_registration PR #927
    • res_rpt_http_registrations: Use ast_str* for url PR #929
    • app_rpt: Keep rpt_exec() thread for processing link audio frames PR #932
    • app_rpt: limit text message size, adjust stat post and link update interval PR #933
    • app_rpt: Handle dialplan execution in handle_varcmd_telem() PR #934
    • Changes for GCC V15 and C23 compliance PR #935
    • build: Fix discarded-qualifiers errors with gcc 15.2.1 PR #937
    • app_rpt: Fix unused-but-set-variable errors with gcc 16 PR #941
    • app_rpt: Remove double debug message on ast_format_cap_alloc() failure PR #943
    • app_rpt: Remove unused MAXNODES created PR#555 PR #944
    • Linklist "randomize" timers PR #945
    • app_rpt: Add RPT_NODE dialplan function PR #957
    • app_rpt: Write channel text messages to rpt_qwrite() PR #959
    • app_rpt: Refactor init_text_frame() PR #961
    • Dev: Keep format for AST_DECLARE_APP_ARGS PR #962
    • app_rpt: Set Exten for outbound calls PR #964
    • app_rpt: statpost should only report adjacent nodes PR #965
    • dev: Add coderabbit instructions PR #967
    • Coderabbit: Fix format and instructions PR #968
    • dev: Fix coderabbit.yaml format PR #969
    • dev: Coderabbit try 2 PR #970
    • app_rpt: Finish generalization of node lookup in extensions.conf PR #972
    • app_rpt: Change default linkpost_time to 30 seconds PR #973
asl3-menu v1.17
  • node-setup: add AIOC customizations PR #103
  • Ensure that the "asterisk" login exists PR #106
dahdi 3.4.0-11
  • Fixes trixie depdency issues (again) PR #5
  • DAHDI Minimization for Less DAHDI Plan PR #6
These packages will be available for the next 2-3 weeks. If we do not hear of any issues or problems with the updates we will promote them to the production/main channel.
Sincerely,
AllStarLink
