2 systems on one LAN, each with an Echolink number
I'll second Jon's advice... Another possibility not yet mentioned is to operate a private Proxy server at another location, and configure your second box to use the proxy for Echolink... I did just that back in about 2006 , although not using App-rpt.. It was all we could do at the time, so it was 100% better than nothing.. However, that brings you up to 3 PCs to operate 2 nodes...
Lastly, you could try what I'm doing here.. At my QTH, I operate several Allstar nodes, and my solution was to connect the Echolink node to a hub node (2210). Through experimention, I found that outbound Echolink calls seem to work fine from any node, even when the RF nodes are not connected to the hub node. I'm not sure if that feature was ever planned, but it seems to work! I normally do not connect the RF nodes to the hub node. Nodes 2210-2213 are all running on a single P3/866 MHZ PC.
If I am expecting an inbound Echolink call (almost never), we can connect any or all of the RF nodes to the hub node.
73 for now.
Kyle
K0KN
Allstar 2210-2215
Based on that info, what you could do is set up 2 Allstar nodes on one
box and setup one echolink node.
Connect each node to repeater. That way its the same as having 2 boxes
(actually simpler) and both nodes can access the echolink.
Jon VA3RQ
--- Original Message ---
On 4/9/2011 7:18 AM, Jim Duuuude wrote:
Well, an installation of Echolink running on 2 nodes behind the same
IP address
can only be found with the Easter Bunny, Santa Claus, all the left
socks that were
ever lost in the laundry and competent, reliable drummers.
In other words, it doesn't exist. The design of their protocol simply
DOES NOT
allow for such a thing. In their world, it's a unique mapping of one
node to one
IP address at a fixed port number set ONLY. That's it. Over and out.
JIM WB6NIL
Date: Sat, 9 Apr 2011 04:40:02 -0500
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] 2 systems on one LAN, each with an echolink
number?
I have 2 AllStarLink systems on one LAN. Each is for a separate
repeater system with a separate computer. They share a common
Internet address.
For AllStar they work fine. For EchoLink I can only make one or the
other of them work, but not both.
Is there a way to change the port number of one of the echolink nodes
so that they can both use the same Internet address?
We want them both to be able to have inbound and outbound connections
via echolink, independent of each other.
Chuck
app_rpt does not support using Echolink proxy. Echolink does not even seem to support Echolink
proxy reliably and consistently :-). Im sure you must have noticed this in the past.
JIM
Date: Sat, 9 Apr 2011 22:03:12 -0500
Subject: Re: [App_rpt-users] 2 systems on one LAN, each with an Echolink number
I’ll second Jon’s advice… Another possibility not yet mentioned is to
second box to use the proxy for Echolink… I did just that back in about
2006 , although not using App-rpt… It was all we could do at the time, so
it was 100% better than nothing… However, that brings you up to 3 PCs to
operate 2 nodes…
Lastly, you could try what I’m doing here… At my QTH, I operate several
the hub node. I’m not sure if that feature was ever planned, but it seems to
73 for now.
Kyle
K0KN
Allstar 2210-2215
— Original Message —
Jon VA3RQ
IP address
socks that were
In other words, it doesn’t exist. The design of their protocol simply
DOES NOT
allow for such a thing. In their world, it’s a unique mapping of one
node to one
IP address at a fixed port number set ONLY. That’s it. Over and out.
JIM WB6NIL
number?
Internet address.
Chuck
ohnosec.org
Convince one of your neighbors to run an asterisk box at his house.
(a mini itx in the basement - he will forget it is even there)
The only thing on that box will be the E/L channel.
Then permalink your second node to this "E/L Hub".
Done.
Ken
number?
Internet address.
Well if youre going to get one of your neighbors involved, why dont you just
get their permission (of course) and have a wireless device on their network
and either put it on your existing LAN (assuming their local LAN netblock is
different then yours) or put in a second NIC card or something. chan_echolink
is perfectly capable of running as many Echolink nodes as you have (public) IP addresses
on your server.
To: rpt2@chuck.midlandsnetworking.com
Date: Sat, 9 Apr 2011 23:15:34 -0400
CC: app_rpt-users@ohnosec.org
Then permalink your second node to this “E/L Hub”.
Done.
Ken
number?
Internet address.
ohnosec.org
Assuming a rural mountaintop location, this might not be real convenient.
The dedicated box would allow it to be anywhere on the planet with reasonable internet service.
The only restriction is that the cooperative person involved must not be running EchoLink himself.
Ciao
Ken
Sent: Saturday, April 09, 2011 11:20 PM
To: ke2n@cs.com; Chuck Henderson
Cc: app_rpt mailing list
Subject: RE: [App_rpt-users] 2 systems on one LAN, each with an Echolink number
on your server.
Done.
Ken
number?
Internet address.
ohnosec.org
Jim,
Interesting, so if I have 2 internet connections, one with a lan 192.168.168.0/24 and the other with a lan 172.16.16.0/24 and I have a server with 2 ip addresses configured, 192.168.168.168 and 172.16.16.16, so far the easy stuff for me. What configuration needs to be done (in echolink.conf I suspect) on that server for 2 independent echolink nodes so that one uses one address and the other uses the other address?
Chuck
on your server.
Done.
Ken
number?
Internet address.
I like Jim’s idea. But add a Virtual Interface to your network card. “eth0:1” Your LAN can handle many different networks. If your running a Linux router you can have lots of fun running two WAN’s. Or ask your ISP for a second IP address. How about using a USB CDMA card “Virgin Mobile Cheap” on the mountain top for the second computer. Then you could just route the EchoLink out the USB CDMA card and use it as a fail over route.
David
on your server.
Done.
Ken
number?
Internet address.
you have to add a second instance stanza in the echolink.conf file (name
it something like el1 instead of el0)
and in BOTH stanzas you need to specify ipaddr= to bind each one to its
associated IP address.
Also, if you happen to have a NAT router that is behind more then one public IP that is capable of
doing explicit public IP/port to private IP/port NAT bindings, you can have both instances on the
same local IP address, but specify port= in both cases and put the second (or third or fouth, etc)
on some strange port number (the port= specifys the lower number of the port number pair to
be used) and then bind the other addresses to other public IP addressses on their normal public
port (5198 I guess it is).
In any case, each stanza would have different echolink login info, and also, have a different
app/rpt node associated with it. For outbound traffic, all connections come from the Echolink
node node number associated with el0.
Remember, this is not archetected like a normal Echolink installation. Multiple inbound and
outbound connections are supported completely and independently of each other.
JIM WB6NIL
Date: Sun, 10 Apr 2011 01:54:50 -0500
To: telesistant@hotmail.com
CC: ke2n@cs.com; app_rpt-users@ohnosec.org
Jim,
Chuck
on your server.
Done.
Ken
number?
Internet address.
