1. Re: . usbradio_tune_xxxxx.conf where .conf = .confusion
Sorry for the mistake. For some reason the previous Xelatec links caused me to think of that.
But it is an address issue. I just got finished with a Xipar node that did the same behavior. Ran fine, Green light lit but no heartbeat.
Despite hot swapping the fobs which resulted in the OS seeing it, I finally realized the tune file forced the selection.
Good luck as I don’t run DIAL
73s
On May 21, 2016 5:38 PM, app_rpt-users-request@ohnosec.org wrote:
Send App_rpt-users mailing list submissions to
    app_rpt-users@ohnosec.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
    app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of App_rpt-users digest…”
Today’s Topics:
    (Steve Agee (Steve Agee)
Message: 1
Date: Sat, 21 May 2016 16:38:16 -0500
To: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] . usbradio_tune_xxxxx.conf where .conf =
    .confusion (Steve Agee
Message-ID: ba084f3d-f4d2-017b-04e4-11c5cace0f7d@earthlink.net
Content-Type: text/plain; charset=“windows-1252”; Format=“flowed”
Thanks, but as previously mentioned, this is DIAL and so your CLI
commands from XIPAR do not exist.
N5ZUA
On 5/21/2016 4:36 PM, KM4NRJ FLORIDA wrote:
Excuse my mistake.
Edit the urd_tune_usb.conf not urd.conf
On May 21, 2016 17:08, <app_rpt-users-request@ohnosec.org > > > mailto:app_rpt-users-request@ohnosec.org> wrote:
If you are using Xipar then under the CLI use:
radio probe on
It will scan all currently connected Fobs and indicate bus and
device number.
radio probe off
will stop the scan.
Edit the urd.conf file to set device parameters accordingly.
Restart Asterisk
On May 21, 2016 17:08, <app_rpt-users-request@ohnosec.org >  > >     <mailto:app_rpt-users-request@ohnosec.org>> wrote:
    app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>
    or, via email, send a message with subject or body 'help' to
    <mailto:app_rpt-users-owner@ohnosec.org>
    specific
    than "Re: Contents of App_rpt-users digest..."
    Today's Topics:
       1. usbradio_tune_xxxxx.conf where .conf = .confusion (Steve
    Agee)
       2. Voter RTCM sometimes offline-mode but not when there is a
          telnet connection (info@rainerbertsch.de
    <mailto:info@rainerbertsch.de>)
       3. Re: usbradio_tune_xxxxx.conf where .conf = .confusion
    (kk6ecm)
       4. Re: usbradio_tune_xxxxx.conf where .conf = .confusion
    (Steve Agee)
    Message: 1
    Date: Sat, 21 May 2016 14:04:56 -0500
    <mailto:n5zua@earthlink.net>>
    To: app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>
    Subject: [App_rpt-users] usbradio_tune_xxxxx.conf where .conf =
            .confusion
    Message-ID:
    <c5dc4bf0-2c2c-3566-f32e-31a311653463@earthlink.net
    <mailto:c5dc4bf0-2c2c-3566-f32e-31a311653463@earthlink.net>>
    Content-Type: text/plain; charset="windows-1252"; Format="flowed"
    Hello list:
    I've searched
      <[http://www.xelatec.com/xipar/node/180](http://www.xelatec.com/xipar/node/180)>
    and I fully understand the description/explanations given.
    What I don't
    understand, with specific attention to the lines:
    >; name=usb ;
    ; devnum=1 ;
    devstr=4-2 ;
    is how to manually uncomment, and manipulate them. In this
    particular
    instance, I'm trying to get a DIAL box running with one
    original URI
    (early version) using the USBRADIO channel driver, and one
    URIX (newer
    version) using the SIMPLEUSB channel driver. I've followed the
    step-by-step (or was that Crossbar 5 Duude?) instructions for
    starting
    off with a single node, then adding the second node. That
    simply doesn't
    work. The second URIx green L.E.D. stays solid throughout the
    process.
    Are these lines provided for informational purposes only, or
    can they be
    edited to force the second device to be recognized and assigned?
    N5ZUA
    -------------- next part --------------
    An HTML attachment was scrubbed...
    URL:
    <[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/7a2b5993/attachment-0001.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/7a2b5993/attachment-0001.html)>
    Message: 2
    Date: Sat, 21 May 2016 22:02:45 +0200
    From: "info@rainerbertsch.de <mailto:info@rainerbertsch.de>"
    <info@rainerbertsch.de <mailto:info@rainerbertsch.de>>
    Subject: [App_rpt-users] Voter RTCM sometimes offline-mode but not
            when    there is a telnet connection
    Message-ID:
    <C881739D-1333-4A44-AF95-0167725A6BCE@rainerbertsch.de
    <mailto:C881739D-1333-4A44-AF95-0167725A6BCE@rainerbertsch.de>>
    Content-Type: text/plain; charset="utf-8"
    Hi there,
    Since November, we are trying to build a voting system.
    We need some help please !
    Hardware:
    Supermicro Intel Atom D525 (we also tried a RaspberryPi and an
    other computer)
    Software: Since yesterday DIAL from Alllstar-Homepage (Before
    we tried it with ACID)
    RTCM from Micro Node, Mark, we have 4 of them and tried all of
    them
    Garmin GPS 18x LVC, also wie tried 4 of them.
    Error:
    More or less often the RTCM switch in the offline mode. When
    there is traffic very often.
    But not if at the same time there is a telnet connection from
    any computer to the  RTCM.
    We suspect a networking problem between our asterisk-server
    and RTCM
    Network-Card is set to 10 MB / s half-duplex like in the RTCM.
    From  tcpdump from server to rtcm we got:
    ??? snip ----------
    GPSTime (cli0_yy): 05/05/16 12:48:01.000000000
    SysTime: 05/05/16 12:48:01.040000
    DrainTime: 05/05/16 12:48:01.000
    Got GPS (cli0_yy): Lat: 4857.60N, Lon: 00915.01E, Elev: 214.4
    sending KEEPALIVE (GPS) packet to client cli2_bprx digest bbb4c643
    GPSTime (cli2_bprx): 05/05/16 12:48:01.000000000
    SysTime: 05/05/16 12:48:01.300000
    DrainTime: 05/05/16 12:48:01.240
    Got GPS (cli2_bprx): Lat: 4853.16N, Lon: 00912.65E, Elev: 317.2
    sending KEEPALIVE (GPS) packet to client cli0_yy digest 79d9c77d
    GPSTime (cli0_yy): 05/05/16 12:48:02.000000000
    SysTime: 05/05/16 12:48:02.040000
    DrainTime: 05/05/16 12:48:02.000
    [May 512:48:03]NOTICE[6559]:chan_voter.c:3632voter_reader:Voter
    lost master timing source!!
    sending packet challenge 200371797 digest 7749985d password
    BLAH sending packet challenge 200371797 digest 7749985d
    password BLAH sending packet challenge 200371797 digest
    bbb4c643 password BLAH GPSTime (cli2_bprx): 05/05/16
    12:48:18.000000000
    SysTime: 05/05/16 12:48:18.320000
    DrainTime: 01/01/70 01:00:00.340
    -- Voter client cli0_yy disconnect (timeout)
    ??? snip  ----------
    Konfiguration of the Ethernet-Card
    # ethtool eth0
    Settings for eth0:
    Supported ports: [TP]
    Supported link modes: 10baseT / Half 10baseT / Full
    100baseT / Half 100baseT / Full
    1000baseT / Full
    Supported break frame use: No
    Supports auto-negotiation: Yes
    Advertised link modes: Not reported
    Advertised break frame use: No
    Advertised auto-negotiation: No
    Speed: 10Mb / s
    Duplex: Half
    Port: Twisted Pair
    PHYAD: 1
    Transceiver: internal
    Auto-negotiation: off
    MDI-X: off (auto)
    Supports Wake-on: pumbg
    Wake-on: g
    Current message level: 0x00000007 (7)
    drv sample link
    Does anyone have an idea what it may be ?
    Why there is no problem with telnet at the same time and how
    can we run the system without this workaround
    Rainer Bertsch
    DF3SY
    URL:
    <[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/9ca14c8a/attachment-0001.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/9ca14c8a/attachment-0001.html)>
    Message: 3
    Date: Sat, 21 May 2016 13:55:40 -0700
    From: "kk6ecm" <kk6ecm@gmail.com <mailto:kk6ecm@gmail.com>>
    To: <app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>>
    Subject: Re: [App_rpt-users] usbradio_tune_xxxxx.conf where
    .conf =
            .confusion
    Message-ID: <638EEEDD093A4435AC75ECFA4CFB35E8@ThePykesHP>
    Content-Type: text/plain; charset="us-ascii"
    run lsusb at the command line, then set devstr=<bus>-<device>
    for the
    device(s) shown. Your example is for Bus 004 Device 002.
    Bob
    kk6ecm
      _____
    <mailto:app_rpt-users-bounces@ohnosec.org>
    [mailto:app_rpt-users-bounces@ohnosec.org
    <mailto:app_rpt-users-bounces@ohnosec.org>] On Behalf Of Steve
    Agee
    Sent: Saturday, May 21, 2016 12:05 PM
    = .confusion
    Hello list:
    I've searched
    What I don't
    ; name=usb ;
    ; devnum=1 ;
    devstr=4-2 ;
    particular
    original URI (early
    version) using the USBRADIO channel driver, and one URIX
    (newer version)
    that Crossbar 5 Duude?) instructions for starting off with a
    single node,
    then adding the second node. That simply doesn't work. The
    second URIx green
    L.E.D. stays solid throughout the process. Are these lines
    provided for
    informational purposes only, or can they be edited to force
    the second
    N5ZUA
    URL:
    <[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/8eb8b1d0/attachment-0001.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/8eb8b1d0/attachment-0001.html)>
    Message: 4
    Date: Sat, 21 May 2016 16:05:25 -0500
    .conf =
            .confusion
    Message-ID:
    <86a1038a-7c34-a1c4-edf1-89da5dead8a7@earthlink.net
    <mailto:86a1038a-7c34-a1c4-edf1-89da5dead8a7@earthlink.net>>
    Yup, tried that early on with no luck. Then tried using the
    (W) command
    in both radio-tune-menu or simpleusb-tune-menu. The
    <bus>-<dev> listed
    in the tuning files does not match what the "lsusb" command
    reports.
    Well, the <bus> matches, but NOT the <dev>. On a working ACID
    install
    under same conditions, I have two (count them two) different
    tuning
    files where "devnum=3" go figure, and it works!
    N5ZUA
    devstr=<bus>-<device> for the
    > Bob
    > kk6ecm
    > 73
    > *From:*app_rpt-users-bounces@ohnosec.org
    <mailto:app_rpt-users-bounces@ohnosec.org>] *On Behalf Of
    *Steve Agee
    > *Sent:* Saturday, May 21, 2016 12:05 PM
    > *To:* app_rpt-users@ohnosec.org
    > *Subject:* [App_rpt-users] usbradio_tune_xxxxx.conf where
    .conf =
    > .confusion
    > Hello list:
    > I've searched
    What I
    > don't understand, with specific attention to the lines:
    > >; name=usb ;|
    > >; devnum=1 ;|
    > >devstr=4-2 ;|
    particular
    original URI
    URIX (newer
    for starting
    > off with a single node, then adding the second node. That simply
    > doesn't work. The second URIx green L.E.D. stays solid
    throughout the
    > process. Are these lines provided for informational purposes
    only, or
    > can they be edited to force the second device to be
    recognized and
    > assigned?|
    > >N5ZUA|
    > App_rpt-users@ohnosec.org <mailto:App_rpt-users@ohnosec.org>
    > To unsubscribe from this list please visit
    [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users) and
    scroll down to the bottom of the page. Enter your email
    address and press the "Unsubscribe or edit options button"
    > You do not need a password to unsubscribe, you can do it via
    email confirmation. If you have trouble unsubscribing, please
    send a message to the list detailing the problem.
    URL:
    <[http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/69ecfba1/attachment.html](http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/69ecfba1/attachment.html)>
    End of App_rpt-users Digest, Vol 87, Issue 33
An HTML attachment was scrubbed…
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/bb5f2886/attachment.html>
End of App_rpt-users Digest, Vol 87, Issue 36
