ASL3 on Pi3B+
Some DTMF run shell scripts execute and some don’t. For example, consider the folowing functions:
995=cmd, /usr/bin/astres.sh ; Restart Asterisk
996=cmd, /usr/local/sbin/reboot.sh ; Reboot PC
997=cmd, /usr/local/sbin/on_normal.sh ; Set ON_normal state
909=cmd, /usr/local/sbin/halt.sh ; Stop PC for power off
*997 works; but the other three don’t. Each of the functions run from CLI without issue.
Thanks for the quick reply Allan. I understand how to change ownership and group. Is there a simple work around for what I’m trying to do? (What would need to have ownership or group changed?)
To be able to gracefully power down the processor from DTMF is important. I don’t want to roll the dice with potential memory corruption by jerking the power on & off. Remoting in with SSH will work; but not always convenient.
This issue is not that the “asterisk” process can’t access/execute the commands. The problem is that you are wanting the “asterisk” process to execute commands that require super-user “root” privileges that it doesn’t possess.
If you think about this a bit more you will (should) remember that to execute these commands from the CLI you would either be logged in as “root” or you would be using “sudo …”.
As for workarounds, the system is running Linux so there are lots of possibilities.
You “could” have a long running “root” process (or a “root” cron job that runs every minute) that watches/waits for a “trigger” file to be created/updated and exec’s whatever privileged commands you want executed. Then, you have “asterisk” update the “trigger” file.
Note: I’ve seen scripts that do the same type of thing but instead of watching a file they would watch for for GPIO pin transitions.
You also “might” be able to set the system up so that the “asterisk” login could execute commands with “sudo”.
Just remember to be very careful that whatever you put together cannot be abused (e.g. you don’t want to have a root level process that blindly executes the contents of a file).
That would defeat the purpose of not running asterisk as root. Probably the right solution here is a PolKit policy that allows the ‘asterisk’ user to call certain patterns of commands like reboot, shutdown, and a few things like that.
It’s general practice that applications that do not need root access do not run as root in an operating system. Asterisk does not need root access and has not for a very long time. ASL1/2 and HamVOIP are based on extremely obsolete versions of Asterisk.
Since may ASL3 nodes sit on the public Internet, we’ve made sure that every aspect of the system is as secure as we can make it.
The tone in these posts is surprising. It seems that many people lack a clear understanding of the differences between Allstarlink, app_rpt, and Asterisk.
Asterisk is an open-source software used for creating and managing communication systems like VoIP and PBX. It is not affiliated with Allstarlink or the developers of app_rpt.
app_rpt is a third-party module for Asterisk that adds features for radio interfacing and control, enabling Asterisk to be used in building advanced radio systems.
Allstarlink is an organization, network, and software package that integrates Asterisk and app_rpt with networking capabilities, making it much easier for users to leverage these technologies without needing to build everything manually.
Recently, the Allstarlink developers released a new beta version that builds app_rpt on Asterisk 20—over 15 years newer than the previous Asterisk version used with app_rpt. This update brings new features, bug fixes, and modern security practices.
To be clear: the Allstarlink developers are not responsible for the updated security practices. Asterisk and the operating system it runs on handle security. Blaming the Allstarlink team for these updates doesn’t make sense.
