I live in Brisbane 2 mil people 10 repeaters no Allstar links would like to get this going and have a linked repeater unfortunately most people are content to have there own node and just pay someone to set it up for them i would like to have a public repeater on for all to use lets know if you can help here are the files what is wrong.
massage is Could not login to Asterisk Manager. could not log in.
any help please. and I haven’t used special characters in password…
[52697]
host=127.0.0.1:5038
user=vk4dcm
passwd=vk4rdbvk4rdb
menu=yes
hideNodeURL=no
[52697]
host=127.0.0.1:5038
user=vk4dcm
passwd=vk4rdbvk4rdb
menu=yes
hideNodeURL=no
[All Nodes]
nodes=52697
menu=no
[lsNodes]
cd /srv/http/supermon
menu=yes
[IRLP Status]
url=“http://status.irlp.net”
menu=yes
[HAMVOIP]
url=“http://HamVOIP.org”
menu=yes
; AMI - The Asterisk Manager Interface
; Third party application call management support and PBX event supervision
; This configuration file is read every time someone logs in
; Use the “manager list commands” at the CLI to list available manager commands
; and their authorization levels.
; “manager show command ” will show a help text.
; ---------------------------- SECURITY NOTE -------------------------------
; Note that you should not enable the AMI on a public IP address. If needed,
; block this TCP port with iptables (or another FW software) and reach it
; with IPsec, SSH, or SSL vpn tunnel. You can also make the manager
; interface available over http if Asterisk’s http server is enabled in
; http.conf and if both “enabled” and “webenabled” are set to yes in
; this file. Both default to no. httptimeout provides the maximum
; timeout in seconds before a web based session is discarded. The
; default is 60 seconds.
[general]
displaysystemname = yes
enabled = yes
;webenabled = yes
port = 5038
;httptimeout = 60
; a) httptimeout sets the Max-Age of the http cookie
; b) httptimeout is the amount of time the webserver waits
; on a action=waitevent request (actually its httptimeout-10)
; c) httptimeout is also the amount of time the webserver keeps
; a http session alive after completing a successful action
bindaddr = 127.0.0.1 ; Local interface only!
;bindaddr = 0.0.0.0 ; Not secure
;displayconnects = yes
; Add a Unix epoch timestamp to events (not action responses)
;timestampevents = yes
[admin]
secret =vk4rdbvk4rdb
