Allstar ASLv3 / Raspberry Pi5 / Shari Pi Hat build
Hello all,
Been working on an Pi5 / with a Shari Pi-hat build and have run into a problem I haven’t been able to solve. The main problem is when I try to make changes to the pi-hat radio using " sa818-menu " I get “connection error” and none of the changes take.
I set up the node following Ham Radio Crusader’s you tube video and the node works with the Shari pi-hat default sa818 settings, I just can’t make changes to the sa818.
Has anyone built an node with this hardware?
Does anyone have any ideas of what to try to solve this issue?
Phil (KF4WLA)
