Hi all
I’ve just spun up ASL3 on my debian 12 cloud VPS, it’s looking good
All the basic stuff looked ok but when I try link commands from allmon 3, I get the message
Command Successful
OK:
Unknown node number 537100.
CLI shows == Manager ‘admin’ logged on from 127.0.0.1
== Manager ‘admin’ logged off from 127.0.0.1
I assume it’s as I am remotely accessing it, any ideas on where to start looking?
Thanks & 73
Rob G4ZWH
Edit: I’ve noticed the node is not actually accepting incoming connections either, CLI log shows this:
Connected to Asterisk 20.8.1+asl3-3.0.0-1.deb12 currently running on None (pid = 391)
[2024-07-01 09:01:06.746] NOTICE[428]: dnsmgr.c:225 dnsmgr_refresh: dnssrv: host ‘register.allstarlink.org’ chang ed from XX.XX.XX.XXX:443 to XX.XXX.XX.XXX:443
– Accepting UNAUTHENTICATED call from XX.XX.XX.XXX:4570:
– > requested format = gsm,
– > requested prefs = (gsm|ilbc|speex16|ulaw),
– > actual format = ulaw,
– > host prefs = (ulaw|adpcm|gsm),
– > priority = mine
– Executing [537100@radio-secure:1] NoOp(“IAX2/X.X.X.X:4570-10271”, “Connect from node: 537101”) in new stack
– Executing [537100@radio-secure:2] NoOp(“IAX2/X.X.X.X:4570-10271”, “Connect to: 537100”) in new stack
– Executing [537100@radio-secure:3] NoOp(“IAX2/X.X.X.X4570-10271”, “The Channel IP is X.X.X.X”) i n new stack
– Executing [537100@radio-secure:4] GotoIf(“IAX2/8X.X.X.X:4570-10271”, “0?connect”) in new stack
– Executing [537100@radio-secure:5] GotoIf(“IAX2/X.X.X.X:4570-10271”, “1?denylist”) in new stack
– Goto (radio-secure,537100,9)
– Executing [537100@radio-secure:9] GotoIf(“IAX2/X.X.X.X:4570-10271”, “0?:connect”) in new stack
– Goto (radio-secure,537100,12)
– Executing [537100@radio-secure:12] Rpt(“IAX2/X.X.X.X:4570-10271”, “537100”) in new stack
[2024-07-01 09:01:20.809] WARNING[814][C-00000002]: app_rpt.c:6295 rpt_exec: Cannot find specified system node 53 7100
== Spawn extension (radio-secure, 537100, 12) exited non-zero on ‘IAX2/X.X.X.X:4570-10271’
– Hungup ‘IAX2/X.X.X.X:4570-10271’
In addition to what N8EI said, looks like there may be a typo (added space) in the node number. Check your rpt.conf particularly the [nodes] stanza for a space.
Also be sure you understand the new Asterisk template system if you are editing the configs rather than using the menu.
Yes I think something at the basic level has gone wrong…!
I used the script, I haven’t changed anything manually. I used fresh install and got the same issue - I will have to manually check the config files when I have a moment.
Rob
CLI command prompt shows
Connected to Asterisk 20.8.1+asl3-3.0.0-1.deb12 currently running on None (pid = 1560)
None*CLI> rpt localnodes
Node
NoneCLI> rpt show registrations
Host Username Perceived Refresh State
x.x.x.x:443 537100 x.x.x.x:4569 179 Registered
1 HTTP registration.
NoneCLI>
root@None:~# dpkg -l ‘dahdi*’
lsmod | grep dah
find /lib/modules/uname -r/ -name ‘dah’
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii dahdi 1:3.1.0-2 amd64 utilities for using the DAHDI ker>
ii dahdi-dkms 1:3.3.0-5+asl all DAHDI telephony interface (dkms k>
ii dahdi-linux 1:3.3.0-5+asl all DAHDI telephony interface - Linux>
un dahdi-source (no description available)
lines 1-9/9 (END)…skipping…
ii dahdi 1:3.1.0-2 amd64 utilities for using the DAHDI kernel modules
ii dahdi-dkms 1:3.3.0-5+asl all DAHDI telephony interface (dkms kernel driver)
ii dahdi-linux 1:3.3.0-5+asl all DAHDI telephony interface - Linux userspace parts
Interesting. Did you have any errors during the apt install process? Please try running apt install --reinstall dahdi-linux. Then do a modprobe dahdi and then rerun lsmod | grep dah.
I didn’t notice any errors… I could do a clean install and look for any errors?
root@None:~# apt install --reinstall dahdi-linux
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 66.7 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://repo.allstarlink.org/public bookworm/main amd64 dahdi-linux all 1:3.3.0-5+asl [66.7 kB]
Fetched 66.7 kB in 1s (116 kB/s)
(Reading database ... 52587 files and directories currently installed.)
Preparing to unpack .../dahdi-linux_1%3a3.3.0-5+asl_all.deb ...
Unpacking dahdi-linux (1:3.3.0-5+asl) over (1:3.3.0-5+asl) ...
Setting up dahdi-linux (1:3.3.0-5+asl) ...
Fetched 66.7 kB in 1s (118 kB/s)
root@None:~#
and
modprobe: FATAL: Module dahdi not found in directory /lib/modules/6.1.0-22-cloud-amd64
root@None:~#
I could reinstall debian 12 and do a fresh install of ASL3 looking for any errors on the way?
root@None:~# apt install --reinstall dahdi-dkms
Progress: [ 80%] [##############################################################################################################............................]
Get:1 https://repo.allstarlink.org/public bookworm/main amd64 dahdi-dkms all 1:3.3.0-5+asl [1190 kB]
Fetched 1190 kB in 1s (1111 kB/s)
Preparing to unpack .../dahdi-dkms_1%3a3.3.0-5+asl_all.deb ...
Deleting module dahdi-3.3.0 completely from the DKMS tree.
Unpacking dahdi-dkms (1:3.3.0-5+asl) over (1:3.3.0-5+asl) ...
Setting up dahdi-dkms (1:3.3.0-5+asl) ...
Loading new dahdi-3.3.0 DKMS files...
Building for 6.1.0-22-cloud-amd64
Module build for kernel 6.1.0-22-cloud-amd64 was skipped since the
kernel headers for this kernel do not seem to be installed.#########################################........................................................]
root@None:~#
root@None:~# dpkg -l 'linux-headers*'
un linux-headers <none> <none> (no description available)
ii linux-headers-6.1.0-22-amd64 6.1.94-1 amd64 Header files for Linux 6.1.0-22-amd64
ii linux-headers-6.1.0-22-common 6.1.94-1 all Common header files for Linux 6.1.0-22
un linux-headers-686-pae <none> <none> (no description available)
ii linux-headers-amd64 6.1.94-1 amd64 Header files for Linux amd64 configuration (meta-package)
un linux-headers-generic <none> <none> (no description available)
root@None:~#
This is definitely not a standard Debian 12 Bookworm VPS installation. Note that “1.0-22-cloud-amd64” – looks like some sort of oddball customized Linux image from Ionos. Try doing this:
and see if anything new installs. But if they’ve stuck in a rando kernel without the corresponding headers there’s going to be problems building the kernel modules. Are you able to install with a stock Debian image?
