Your VOTER/RTCM May Have Broken Itself on 01/01/21 00:01
Hi Chuck,
I don’t believe that is going to help in this case. I am running a similarly modified firmware (have been testing a number of similar changes to what you have in that branch), and they were all running fine, until we rolled over on NYE.
The problem isn’t a week rollover issue, it is a bug in the mktime routine, causing it to return -1 when you send it the tm struct to convert to epoch time.
That causes gpstime to be -1, so, it always starts counting at something like Dec 31, 1970 at 1600 (I can’t recall the exact time off the top of my head).
So, resetting the GPS, always causes it to start counting from that date, regardless of what the real date/time is.
At least, that is what I am seeing on both the TSIP (Trimble) and NMEA devices I have access to, they’re both behaving the same (and were previously working just fine).
I think the fix will be to convert the date/time from the GPS to epoch with a stand-alone function, that doesn’t use the built-in mktime from time.h.
Unfortunately, the box I was using to compile test code on decided to blow up (thanks Microsoft updates), so I haven’t had a chance to compile and test a fix, yet.
Lee
