Our LARGE 900 MHz Allstarlinked network is having problems due to blank status pages for many of our hub servers. For example 4170, 42610,and 29521 (just to mention a few).
Regards,
Tom / K5TRA
@Tom Is this still going on for you? 4170 is not a public node number. Maybe you meant 41170? Currently 41170 , 42610 and 29521 all appear registered on the Allstarlink nodes list.
Stat server not up right now
Www is back but stats is still not fixed
Now stats is online as well
Stats server problem again today - no bubble map.
Tom
I just tried it and it seems to be working ok. Please paste the url of what is not working for you.
When I look for bubble-map connections: http://stats.allstarlink.org/getstatus.cgi?41170 , I get: NODE INFO NOT FOUND! (after some considerable time delay). Also, same result for 42610. Both hubs have many working connections.
Tom
That is odd. Only some of your node numbers not showing
Right. The main two hub nodes are among the ones with NO bubble map.
Tom
Tim, try http://stats.allstarlink.org/getstatus.cgi?41170 or http://stats.allstarlink.org/getstatus.cgi?42610 .
You will get the message: NODE INFO NOT FOUND!
This has been a problem for several days.
Tom
I’ve also requested help through the “help desk” . This selective bubble-map access is a problem that has started during the past week.
Again, http://stats.allstarlink.org/getstatus.cgi?41170 or
http://stats.allstarlink.org/getstatus.cgi?42610 do not work. Some other nodes result in bubble map displays.
K5TRA
Those are both working now.
Yes, all is good. Thank you.
Tom
Tom,
The bubble-map should be working now.
Marshall -ke6pcv
From: Tom via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Friday, October 09, 2020 11:14 PM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] Yet another - - registration problem
Tom
October 10
K5TRA
In Reply To
Tom
October 10
Tim, try http://stats.allstarlink.org/getstatus.cgi?41170 or http://stats.allstarlink.org/getstatus.cgi?42610 . You will get the message: NODE INFO NOT FOUND! This has been a problem for several days. Tom
Previous Replies
Tom
October 10
Tom
Tom
October 10
Tom
George_Csahanin
October 9
Tom
October 8
Tom
wd6awp ASL Admin
October 8
Marshall,
Yes, it is working now. Thanks again.
Tom
