Hi,
I am not sure that it is the right place to send information about a problem with chan_echolink module in Allstarlink.
When we use echolink Android application to connect echolink node running on Allstarlink always in status node ASL display wrong number echolink node connected to ASL. For example, my echolink node is 926515 and when I connect to my ASL echolink node in status “Node currently connected to us” is showed number 3437911 (whre 3 on begining is added by asl) - I have use command rpt stats 1999). When I look at http://echolink.org/logins.jsp I found that echolink number node 437911 belongs to KO4AVA. When I disconnect and connect again to ASL the my number EL was changed to another 876316 and when I check on EL status page I found that the number belongs to DV2EVE.
But when I use the software PC version echolink the number my echolink node in status ASL is correct 926515.
Does it look like bug ASL which not properly get information about connected number EL node with the station who uses EL Android application?
73 Waldek
