It is basically working but we get intermittent un-authorized eros during the connection. In most cases retrying the connection if you are using an echolink client resolves the problem.
If you are going through allstar this seems to be a near permanent failure.
That is a error on echolink software, not the echolink module of app_rpt/asl.
If you are using a PC or phone version of EL on the same connection as your ASL/app_rpt, that is on the same IP,
one or more are gonna fail everytime.
Echolink only allows one connection per IP address.
So, if you turn the wifi off on your phone (not just close the app because it likely will run in the background) and or disconnect the pc, one of them will work. But only one per IP at a time.
I receive this all the time on my nodes as well. I usually ignore it and it doesn’t seem to affect incoming traffic for me. I suspect it’s their servers going up and down… not sure!
