Please move if Posted in the Wrong Area
I wasn’t able to find any similar posts so apologies if it’s been posted Prior.
I’m connecting 2 MCS2000’s to a USB-RIM Lite to make a Repeater but I have hit a Small snag which I hope someone may be able to clarify.
I have the RX with Pins 8,10,11 Connected to the RIM
I have the TX with Pins 10,21,23 Connected to the RIM
With Duplex 0 enabled, If I Transmit to the RX the audio is not Passed to the TX however if I connect to my node with say zoiper I can hear the Audio coming thru.
If I unmute the mic for Zoiper then the TX Radio does Key UP and transmit.
I have tried changing the Duplex options from 0,1 and 2 but when I choose 1,2,3 or 4 then the Tx does key up but stay keyed after the receiver cos has ended needing me to restart the Asterisk Server.
Is there a way of getting not just the audio into Allstarlink but also to the TX radio for local repeater functionality or is this simply not an option.
Also if anyone has a Good Config file for these Radio’s that I can compare to mine that would be appreciated.
Rob…
