Two nodes, one accepts calls, the other doesn't
Allmon3 is a http connection to the server asterisk management interface.
Not a iax connection to the node.
Take a look at the firewall
sudo ufw status
It’s just worth a look.
I think the issue is just a little more simple and fundamental.
Can you verify the ip address of the server.
curl https://api.ipify.org
you might also look at the ipv4 setup in your networking. Check that against the guide provided at vutlr.
Rather that turning off the firewall you can add a rule you can later delete if you wish.
sudo ufw allow from 0.0.0.0 proto udp to any port 4569
But I am curious if you used a deb12 install from vultr or loaded an iso of deb12?.
I nuked the Vultr instance and started over again. I did pretty much the same procedure, but somehow it works this time. But there’s one caveat. I disabled ufw. Of course it’s a temporary fix for now.
I’ll make ufw settings the basis for a new topic.
