Trouble with echolink on my allstar node
I have node #47199 and can’t seem to connect to anyone or have them connect with me via echolink. The node shows up as a echolink node
Since the website change I don’t see a echolink enable spot like before. Any ideas
Tnx
Scott, AB1MC
First thought is port forwarding… have you forwarded the Echolink ports?
The new web site cannot download a configuration to your node. All Echolink setup must be done locally on your node. Our new WiKi is helpful for that task. Look at the wiki and let us know if you have any questions.
https://wiki.allstarlink.org/wiki/Echolink_Channel_Driver#Debugging
I did check the port forwarding, but it still could be at fault. I will go over it again. Just changed ISP from spectrum to FiOS
Echolink was (is) still acting up
On Wed, Sep 25, 2019, 20:55 Tim Sawyer via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
wd6awp
      ASL Admin
    September 26
